Old 06-10-2009, 06:21 PM
H2inMD H2inMD is offline
H2inMD is off the scale
Default Ramps for H2
what is everybody using.
Rhino Ramps 12,000 lb only takes tires up to 10" wide.
I need a set of ramps.
thanks
Old 06-10-2009, 10:15 PM
Easy Ed Easy Ed is offline
Default Re: Ramps for H2
3 ton floor jack to lift it and four 6 ton jack stands to set it on when I rotate tires and change the oil and lube the grease zerks.
Old 06-10-2009, 11:02 PM
[__--MUD--__]'s Avatar
never liked ramps...I use jacks also.
Old 06-10-2009, 11:14 PM
splne1's Avatar
splne1 splne1 is offline
BLOCKS!!!!
Old 06-11-2009, 03:40 AM
HumminNBoatin''s Avatar
Just find a bit landscaping boulder and put it in your yard. Drive your H2 up on it when you need the room ahahahhhaha.
Eric
Seriously I dont even have to jack my truck up to change oil etc.... However I am running 2" of lift and 37's. And I dont rotate tires myself I got free lifetime rotation when I bought them.
1998 Am General H1 HMCO
Eric@TheHummerClubInc.com
Old 06-11-2009, 01:36 PM
HummerJim's Avatar
I don't trust ramps or concrete blocks much. I'm a firm believer in hydraulic jacks backed up with commercial grade jack stands. I've had a Torin 20 ton, long shaft hydraulic jack for many years and they are hard to beat cost and quality wise. I know it's overkill, but it's better to have too much jack than too little. This is a newer model, but similar to the old one in design and price. You can use it manually or with your air compressor.
http://www.northerntool.com/webapp/w...55?cm_vc=C5503
