Old 06-29-2009, 03:36 AM
ehaser ehaser is offline
ehaser is on a distinguished road
Default Best Cold air intake? Volant, K/N, Airaid?
Does anyone have advice on which of these air intakes would be the best for an 06 SUT? I've heard the Airaid's were loud? I'd like some simple performance mods. Plan to do the exhaust, CAI, Ecu reprogram.
Any others that you guys would recommend.
Old 06-29-2009, 01:38 PM
mbdougl's Avatar
mbdougl mbdougl is offline
mbdougl is off the scale
Default Re: Best Cold air intake? Volant, K/N, Airaid?
Unless you are building a show truck don't waste your money on an intake, the factory one is just fine and if you remove the baffle it will roar loadly when accelerating and you will have to clean and reoil the filter. Not worth the money in my opinion.
Old 06-29-2009, 08:59 PM
kchummer's Avatar
kchummer kchummer is offline
kchummer is on a distinguished road
^^^^^^^^^^^^^^^^^^^^AGREED^^^^^^^^^^^^^^^^^^^^^^
But to answer your question....VOLANT by far....only because it's a lot like the stock setup.....it doesn't let additional hot air around the intake like K&N does, it's sealed off properly
Old 06-29-2009, 09:29 PM
IRA51's Avatar
IRA51 IRA51 is offline
+ 2 ,the stock setup is all you need .
A government big enough to
you have.
-- Thomas Jefferson
Old 06-29-2009, 10:48 PM
lasvegash2's Avatar
lasvegash2 lasvegash2 is offline
lasvegash2 is on a distinguished road
i prefer the stock box with the airaid factory drop-in....
scott j.
2008 h2 sut
2008 escalade
1969 charger
Old 06-30-2009, 01:54 PM
wingn69's Avatar
wingn69 wingn69 is offline
I like my K&N 77 series but mine is also for show, looks better than factory does that for sure.
Old 06-30-2009, 08:31 PM
IRA51's Avatar
That setup might work if it is cold enough outside ,but as soon as it hits 75 degrees outside than it will not preform as well as the stock unit. it will also get the K&N oil on the MAF . causeing you to clean the MAF from time to time. And it will let more dirt into the engine than the stock filter .
you have.
-- Thomas Jefferson
Old 06-30-2009, 08:41 PM
splne1's Avatar
splne1 splne1 is offline
I like mine too. I have that unit also. I guess it's all about prefrence. I Never had to much oil on my MAF sensor either, I have only cleaned it once in 2 years. Just don't go overboard putting to much oil on it. As for the roar, yep can't deny it. It is loud as hell at acceleration!!! The heat shield does a pretty good job at keeping temps down but yeah don't expect super low temps on a hot day.
Old 06-30-2009, 09:11 PM
wingn69's Avatar
I have no problems with mine. I've ran it threw the MT of Austria and at sea level in Italy and all over Germany with no issues. Clean it once a year like K&N tells you never have any over heating issues or oil. mine is matched up with a borla exhaust I'm happy neighbors might not be
Old 07-07-2009, 07:39 PM
iccon's Avatar
iccon iccon is offline
iccon is on a distinguished road
these guys are right I put cold air box on my hummer and there was no improvement other then sound better.
cheers
Old 07-07-2009, 08:49 PM
IRA51's Avatar
You can lead a horse to water,but you can't make him drink .
you have.
-- Thomas Jefferson
Old 07-08-2009, 07:55 PM
cheers
All aftermarket intakes suck and you will lose power and waste money
Old 09-29-2009, 03:06 AM
ema ema is offline
ema is on a distinguished road
I am going for volant cold air intake. An acquaintance visited that site for one system. The modification is relatively cheap, just fair for a decent increase in hp.
Old 09-29-2009, 06:32 AM
HummBob's Avatar
HummBob HummBob is offline
I Love my VOLANT!!!
Plus they have AMAZING Customer Service!!!
BLACK \'04 H2 LUX
BLACK \'07 ESCALADE
Old 09-29-2009, 01:24 PM
Luv2Camp Luv2Camp is offline
Luv2Camp is on a distinguished road
Smile Re: Best Cold air intake? Volant, K/N, Airaid?
Is that not the purpose of the intake? to suck???
Old 09-29-2009, 08:21 PM
IRA51's Avatar
if you dyno it with the stock air box with a new air filter and than your new set up at the rpm range you will drive it in ,you may discover that it looks kool but doe's little or nothing for preformance . and the hotter it gets the worse the aftermarket set up is .as my 83 year old father said to my nephew ,that tatoo may look kool to you but it won't make you any more a man .
you have.
-- Thomas Jefferson
Old 01-14-2010, 05:41 AM
tcalz06 tcalz06 is offline
tcalz06 is on a distinguished road
has anyone heard of a cold air kit setting a check engine light?
I'm looking at a 2003 H2 and the owner says that it sets a check engine light and that if you keep your foot out of it it goes off.
He claims the cold air kit pulls in too much air.
I've never heard of anything like this
Old 01-15-2010, 01:35 AM
Since I'm doing the diesel conversion, I will no longer have a use for my Volant CAI.
It's on my '06 SUT. (I mention that because it's different than the Volant I had on my '03)
I'll sell it cheap but just so you know, it won't be available for a month.
Mark
Old 04-09-2011, 12:53 AM
want2bfast want2bfast is offline
want2bfast is on a distinguished road
I just installed my KN intake now my check engine light is on? Any one else have this issue?
Old 04-12-2011, 06:59 PM
IRA51's Avatar
CLEAN THE OIL OFF YOUR MAF WITH ELECTRIC PARTS CLEANER ,CLEAR CODE BY DRIVEING 3 OR 4 DRIVE CYCLES .
you have.
-- Thomas Jefferson
