Old 07-09-2009, 11:38 PM
Eric1h Eric1h is offline
Eric1h is on a distinguished road
Default Factory alarm problem!!
So i recently had my H2 broken into, it was ridiculous how easy it was for them to get into, they simply popped the drivers door lock clean out of the door!
It was bugging me why the alarm didnt go off, because it was sitting in my driveway... Anyway so today i checked the make sure the factory alarm was even working, and guess what, IT'S NOT!
So, if i sit in the truck, lock the door twice with the remote, the little icon onthe dash comes on, when i open the door, the light just blinks, no horn, but if i put the key in the ignition and turn it one click, then the alarm sounds.
WTF!
ALso, before, the break in, i noticed that every once in awhile, i would get out of the truck, the the radio woud mysteriously come back on! I would have to get back in, put the key back in and turn it on and off to get it to shut off..
I had the problem with the key lock switch before, so i had switched that out already, any ideas???
2003 Hummer H2 Adventure package
Old 07-22-2009, 12:43 AM
solarflare's Avatar
solarflare solarflare is offline
solarflare is on a distinguished road
Default Re: Factory alarm problem!!
might be a bad ignition switch again....I would have it replaced again.
2007 Hummer H2
2010 Jeep Rubicon
Old 07-23-2009, 03:37 PM
pdsq99f4 pdsq99f4 is offline
I bet the switch is off a tooth. Very easy to mess up if you don't know how they get clocked. Do you have to turn the key a little farther than you think you should to start it?
