Old 07-30-2009, 05:14 PM
PETWERH2's Avatar
PETWERH2 PETWERH2 is offline
PETWERH2 is on a distinguished road
Angry 03 A/C Issue Eating Belts BAD Rattling Noise HELP! PLEEESE..
OK, we are having a massive heat wave and this is a VERY serious issue!!!
03 H2 with 60 miles on it. we have owned it for 1 year. in the last 4 months, we have gone through 3 A/C belts ( we are on #4 as of last night) the belts keep breaking.
When A/C is running are idle, everything is fine, at about 1500rpm you get a nasty rattling noise. We figured out that the belt tentioner was doing the rapid bunny hop and making the noise.
OK fine, we had the tensioner replaced. New belt. Same problem. Since the new tensioner 2 more belts have broken.
Funny thing is the A/C works fine WHEN THE BELT IS IN ONE PIECE!!!!!
and when the rpm is below 1500 or above 1750.
One more thing....it's intermittent Most days it makes the sound but sometimes it does not.
SO, any ideas? Could i have just gotten a "dud" tensioner? Could there be another issue?
ANY HELP WOULD BE APPRICIATED......I'm dying here
Old 07-30-2009, 07:22 PM
IRA51's Avatar
IRA51 IRA51 is offline
Default Re: 03 A/C Issue Eating Belts BAD Rattling Noise HELP! PLEEESE..
1 make shure you clutch fan is good so it pulls lots of air across the rad and condenser
2 get the condenser clean and free of bugs and dirt
3 have the compressor checked ,replace if needed with a new or rebuilt one.
also if your over charged it can cause the compressor to lock up when it is hot .
A government big enough to
you have.
-- Thomas Jefferson
Old 07-30-2009, 07:34 PM
PETWERH2's Avatar
OK WILL DO
SAME HERE CAN DO
3 have the compressor checked ,replace if needed with a new or rebuilt one.WHAT DO YOU MEAN BY CHECKED? IS THIS NOT A CASE OF IT WORKS OR IT DOES NOT? CAN IT WORK INTERMITTENTLY?
also if your over charged it can cause the compressor to lock up when it is hot .I DON'T THINK THIS IS THE ISSUE AS THE AC SEEMS TO WORK BETTER AFTER THE VEHICLE HAS BEEN RUNNING FOR A WHILE EI 15 - 20 MINUTES OF DRIVING WITH A/C ON
Old 08-01-2009, 05:07 AM
maybe a bad tensioner? again?
Old 08-01-2009, 07:39 PM
IRA51's Avatar
if the compressor is starting to go bad it will be harder to turn and break a belt. I assumed you checked the tensoner and it was good .
you have.
-- Thomas Jefferson
