Old 08-03-2009, 11:08 PM
Matthewts Matthewts is offline
Matthewts is on a distinguished road
Default Will they fit ?
On a budget and looking to replace my stock H2 rims with Mazzi Hulk (in black). I will stick with the 17" rims so that I can use my low mileage factory BFG 315/70/17's. I am being told that they only come in the 17x10's with a -12 offset. My question is will they fit without rubbing ? This is a street-beater and not an offroader. It is a tight fit in the garage now (the luggage crossbars rub just a little) But I would assume with the additional width that it wouldn't be any taller and even a little shorter as the tires span the 10" rims. Am I on track or way off?
Thanks,
Matt
Old 08-04-2009, 12:24 AM
ROUSHDEMON's Avatar
Default Re: Will they fit ?
You're on track, it wouldn't be any taller at all... and no, you will not rub at all, the stock H2 wheel have a +18mm offset as I learned here not to long ago, anything below that will stick them out further saving you from rubbing, you're good to go bro, post some pics!
2003 Black H2:
2006 Blue H2:
Old 08-05-2009, 04:07 AM
[__--MUD--__]'s Avatar
I'm pretty sure there is 3 different offsets available on the 17's...up to -20.
I have them in 24's
