Old 08-12-2009, 01:11 AM
dlinden200's Avatar
dlinden200 dlinden200 is offline
dlinden200 is on a distinguished road
Default 50,000 mile transmission flush, no filters
Thought I'd share.
Cost for 50,000 fluid changes in Northern Central Illinois.
I change my own motor oil.
Dealer:
Transmission flush + drop oil plan for filter replace +16 qts: $260
rear diff: $150
front diff $150
trans case $150 Total: $710
Aamco:
rear diff: $110
front diff $110
transfer case $110 Total: $590 minus $10 coupon WOW!
Local Express Lube:
Transmission flush + drop oil plan for filter replace +16 qts: $160
rear diff: $70
front diff $70
trans case $70 Total $ 370.
Well I took it to the local lube shop, which in addition is only 6 blocks from my house.
But I was told there are NO transmission filters available.
The dealer said that in the transfer of Hummer ownership they are acummilating a back log of parts. The dealer cannot get them. So the lube shop did not drop the oil pan. So flush was only $100.
They said my transmission oil had normal wear,
but the rear and front diff. was black.
