Old 08-29-2009, 09:07 PM
DanF DanF is offline
DanF is on a distinguished road
Default Problem with my H2 SUT Hummer
I have recently put on 22 inch XD Rockstars with 325/50/22 Nitto Terra Grappler AT Tires. All seemed well they look great except I have an issue when i try to turn the truck fully, whether making a 3 point turn or a U turn, the wheels seemed as if they were hitting the truck and nearly not allowing the car to go any further. I tested to see if the tires were infact hitting the truck by putting it in park, spinning the wheel fully and seeing if there was contact; no contact was found.
What could the problem be? Are 325/50/22 the wrong size tire?
Thanks in advance - Dan
Old 08-30-2009, 03:14 PM
kchummer's Avatar
kchummer kchummer is offline
kchummer is on a distinguished road
Default Re: Problem with my H2 SUT Hummer
in park outside of truck, wile turned fully, u willnot see it toucHin...but if u literally turn wile inside of truck, it turns a little furtHer wHen ure puttin pressure on tHe steerin wHeel ratHer if u were not puttin pressure....best i can describe....do it yourself and youll see you can turn it a little furtHer w/ pressure.....best i can do, mine does same w/ minimal rubbin
Old 08-30-2009, 03:16 PM
kchummer's Avatar
to reinerate my point, tell someone to turn weels wile ure lookin and youll see wat im sayin....
