Old 09-01-2009, 04:15 AM
Blackwidow Blackwidow is offline
Blackwidow is on a distinguished road
Default Is 36500 a good price for 1999 wagon??
I'm sopposed to be getting my first h1 tomorrow and I'm getting a little paranoid. It is a black 99 wagon with winch, bumpers, rack, tons of lights, and the body and interior are 9 out of 10. only problem is it needs a new ac compresser Dealer is asking 36500. Is this a good deal? Please let me know asap. Thanks
Old 09-01-2009, 06:34 AM
ssgharkness020147's Avatar
Default Re: Is 36500 a good price for 1999 wagon??
Is it at a HUMMER dealer? Why aren't they fixing the AC? Its not a bad price, but is high considering where the markets at. If its at a HUMMER dealer the price would be about right. I'd say about 34.5/35,000 would be a better price.
1997.5 Black Slantback
The Sole Remaining God Father
-007=
How many miles are on the truck?
-007=
Old 09-01-2009, 04:53 PM
HumminNBoatin''s Avatar
Its hard to put a price on an H1 really. Make sure you go over the whole truck. If it was an offroad truck do NOT purchase it without putting up on a lift and shaking it all down. I do not think you are getting ripped at that price at all. Sounds fair but there is always room for negotiation lol.
1998 Am General H1 HMCO
Eric@TheHummerClubInc.com
Old 09-02-2009, 09:15 PM
BigKofJustice's Avatar
BigKofJustice BigKofJustice is offline
BigKofJustice is on a distinguished road
Interior and body is only part of the whole package.
I'd have a paid inspection at a good H1 dealer, do not rush to buy your first truck, the price they are asking is very very average, there are many trucks in the 30-40k bracket ranging from 98 to 2001 series trucks.
Whenever I look at an H1 I crawl underneath it even before checking out the interior. It blows the minds of the sales guys at used car lots.
I look at the control arms and frames to see the condition. This is a very easy thing to check to see if your truck has been wheeled. If they look clean/good paint with no chips or scratches, then it's generally a street queen.
I then look for wet spots/leaks, I check all the seals around the geared hubs, the steering gear box, motor and transmission/t-case and the differentials. I'll look for damage and missing parts/exhaust [you'll need some H1 knowledge to be able to spot missing things].
If it can be put on the lift, I'd check the condition of the ball joints, upper and lower to see if there is any play. I'd check under the hood and look at the cooling shroud around the fan for any cracks. I'd look at paint on the springs to see if there is wear marks in between the springs [signs of jumping]. I'd check the plastic around and below the battery box for damage [signs of abuse, this part is cheap plastic and if its intact on older trucks then it hasn't seen much action IMO].
I would check the condition of the battery cables, starter cables and engine harness for signs of obvious repairs or hack jobs.
Inside the truck I would make sure all windows and door locks operate normally. I would check to make sure all guages and lights work. Look for any abs / check engine lights.
On the test drive, the truck should get up to 190 degrees temperature when hot. voltage should be 13-14v engine pressure on a 6.5 Turbo should be 40 psi cold and around 20 psi hot when idle going to 30. It's ok if the guages are a bit off, because they're not that accurate.
Check transmission and t-case operation in all ranges, check to make sure cruse control works. Check CTIS operation, deflate front and rear wheels a few lbs, then inflate them back up. If you hear a pop pop pop noise thats the overpressure valve blowing off pressure indicating a blockage somewhere. If the system is bypassed [usually with aftermarket rims] assume the CTIS system needs repair or isn't working and take a few dollars off.
Body wise check for rust bubbles INSIDE the wagon fender under the carpet and outside around the roof fender interface.
If you are in southern California, take the truck into Tustin Hummer for a PPI, ask for Mike, hes a 18+ year AM General tech and knows these trucks inside and out. If not see if theres a good local H1 tech in your area.
Check the other H1 owners forums [hml/humvee.net] and see if there is a owner close to you that can look at the truck with you.
Off the top of my head, that's it, but I'd be open to looking at trucks anywhere in the US, don't limit yourself to just buying trucks in your immediate area.
Kurt Williams
1998 H1 HMCO Model 90 6.5L Turbo Diesel
Old 09-08-2009, 12:43 AM
Metallic Red's Avatar
Metallic Red Metallic Red is offline
Metallic Red is on a distinguished road
WOW!! BigKofJustice . I would say that about covers it. Very well said.
2004 Hummer H2 " Metallic Red "
20 inch Mojave's (Teflon)(325/60/20) BFG A/T's
MagnaFlow kitty back...Hypertech Tuned..Music to my ears
HCMI Member 50043
Old 09-09-2009, 12:30 PM
BACKNBLACK's Avatar
BACKNBLACK BACKNBLACK is offline
BACKNBLACK is off the scale
If you are looking at just the interior than you better be paranoid. H1s (Ive had 3 of Them) They are a beast of a whole other species. YOU MUST MUST MUST get a report from any Hummer/GM Dealer that can run the vin to see what has been done if anything to the H1 over the past 10 years. $36,500 is way to steep for a 99. Its not worth over $30 at the auctions. Iam a wholesale car dealer and 99's are selling $27-$29 MAX. I dont want to rain on your parade but owning an H1 is very costly and frustrating. Unless you are preparred to spend a great deal of money (Cause 99's need lots of help) than I would not settle for anything less than a 2003 model with an extended warranty.
Here is my H1 over the winter time.
CURRENT HUMMER:
Number# 11 2007 H3x Desert Orange
SOLD BUT NOT FORGOTTON
1995 H1 350 HT GAS Black
2001 H1 Open Top Black
2004 H2 SUV Yellow
2004 H2 SUV Black
2005 H2 SUT Black
2006 H3 ADV Black
2006 H3 ADV RED
2008 H2 Black/Sedona
2009 H3T Alpha Solar Flare
Old 11-02-2009, 07:04 PM
pdxhummerguy's Avatar
pdxhummerguy pdxhummerguy is offline
pdxhummerguy is on a distinguished road
I will sell ya my 2002 Wagon for $40,000 if your interest. Hasn't been offroad and is in perfect condition
Take a shot of get right and wash it down with a pint of man up and let's get on with things!
Old 11-03-2009, 12:50 AM
BACKNBLACK's Avatar
Color, Pics and Vin Please. Iam interested in your 2002.
CURRENT HUMMER:
2004 H2 SUV Yellow
2004 H2 SUV Black
2005 H2 SUT Black
2006 H3 ADV Black
2006 H3 ADV RED
Old 11-03-2009, 12:57 AM
http://www.elcovaforums.com/forums/s...ad.php?t=33973 VIN:137FA84392E196376
call me if you're interested. 503-888-5008
