Old 09-11-2009, 06:55 PM
HummerRidin26"kmc's HummerRidin26"kmc's is offline
HummerRidin26"kmc's is on a distinguished road
Arrow Repainting interior peices?
was needing info on how to go about redoing my steering wheel buttons and headunit buttons. The paint has chipped off like every other h2 ive saw thanks for your time an info oh yes an also if anyone has information on reducing interior noises like center console rattle ect thatd be nice too. lol
RickyFNRoss
Old 09-14-2009, 02:05 AM
HumminNBoatin''s Avatar
Default Re: Repainting interior peices?
Just buy new steering wheel butttons. They are pretty cheap. Cannot remember exactly how much but I am thinking like $30/ea at the most. I have replaced because of the backlites going out in the past.
1998 Am General H1 HMCO
Eric@TheHummerClubInc.com
Old 09-14-2009, 02:35 AM
Luv2Camp Luv2Camp is offline
Luv2Camp is on a distinguished road
If your replace the steering wheel controls, the BEST way to replace them without damaging your wheel or the connectors on the harness is to remove the wheel. After you remove the wheel, remove the plastic housing on the back of the wheel (2 torx screws) This will give you access to the wire harness. Move the harness towards each side of the wheel as you replace the switches on that side and you will have plenty of wire to pull up to give you room to get to the VERY small plastic clips on the harness. To get the airbag out so you can remove the wheel, there is a small hole on either side of the steering wheel. You can insert a small flathead screwdriver on each side and the bag will pop out with slight pressure. One wire clip and one bolt and a tug on the wheel is all it takes. Knowledge of how to handle air bags safely is needed so leave it to a pro if needed!
Old 09-14-2009, 08:07 PM
Really all you need is a small flat head screw driver and a small pick. Use the small flathead to pry out the button from the wheel. Then use the pick to release the small wire harness. its pretty simple and should take no more than a minute or 2 to do. Just be gentle helping that button un seat from the wheel not to damage the foam on the wheel.
