Old 09-17-2009, 05:39 AM
SWAFIA SWAFIA is offline
SWAFIA is on a distinguished road
Angry Dam Air Suspension
hello i be a newbi
i have a 2004 h2 lol that doent like me anyway a few days ago i came out to the hummer and the battery was dead didnt think anything of it so i jump it and went on my way well the next day i came out and the ass end was down to the wheels so i turned the hummer on and it started but no pumping for the air suspension so i checked the fueses and all check good. The pump and all are under the driver seat right if not where is it, so i can check for power to the mod and pump if so anyone have info on what to check first i do have the circuit layout. i think there is a leak and the pump burned up thats why the batt died but when that happen the h2 was level so iam stumped for now any info would be great
lol a repair manual would be great!!!!
Old 09-17-2009, 04:04 PM
porschett's Avatar
Default Re: Dam Air Suspension
Another post that gave me a headache. Can you please use commas. periods, etc.?
2009 H2 Hummer It's here!!
2006 Baja Performance 88 MPH
2008 GT2 Porsche
2009 DBS
Old 09-17-2009, 06:52 PM
Dont be a prick just looking for help
Old 09-17-2009, 07:23 PM
HumminNBoatin''s Avatar
The compressor is under the truck in the back. If you lay under the rear of the truck you will see a steel plate in the center rear of the truck. The Compressor Assembly is mounted on top of this. Your truck will not pump up the suspension if any doors are open. So Start the truck, close all the doors and I bet you hear it start running.
If your compressor fails to run and your fuses are seem to be fine replace the relay. Its located in the engine compartment toward teh bottom of the firewall on the drivers side. Its a small grey box. You can pick these up pretty cheap.
Sounds like you have a leak in the system. Odds are its just aging bags. Squirt them with soapy water and see if they make any bubbles. They usually leak where they fold over the cup. Replacing the bags is easy. In fact pretty much self explanitory.
1998 Am General H1 HMCO
Eric@TheHummerClubInc.com
Old 09-17-2009, 10:35 PM
sweet ill take a look and try your ides thanks alot ill get back with u and tell u how it went
Old 09-17-2009, 10:47 PM
ok i started the truck and shut the doors then moved the truck 10 feet nothen so i hit the tc2 button and it jacked right up then i shut the truck off and it went to back to level so now iam going to wait till tommarow and see if it goes back to the tires and if it does the its a leak so wish me luck thanks for every thing swafia
Old 09-18-2009, 03:01 AM
tc2 has nothing to do with ride height. TC2 stands for Traction Control 2. This allows you to paddle your way through deep mud or sand as apposed to Traction Controll stopping any wheel spin.
The button below it with a pic of the back end and an arrow is your extend ride height button. Also You do not have to hit that button to lift the truck back to stock height. Just start the truck and shut the doors. It should kick the compressor on and lift to normal ride height.
