Old 09-23-2009, 02:56 AM
Default 2003 NOT Unlocking!?!?
Hey people,
I've got an 03 and for some reason, when I unlock the doors with the fob, the truck won't allow me in through the rear doors (that's what she said)...but seriously, the rear doors won't unlock nor will the rear hatch.
This is happening with both key fobs and although I can manually unlock the rear doors, I can't get the back open.
Its ont just the fob, when I hit the unlock buttons inside the front doors, the rear doors and the back hatch will still not unlock.
Any ideas?
Thanks!!
-Matt
06 - Black Caddy SRX
Old 09-23-2009, 03:10 AM
Default Re: 2003 NOT Unlocking!?!?
I'm searching the older posts now and see some others had the same issues...Anyone find an answer?
Thanks!!
-Matt
Old 09-23-2009, 05:25 AM
ROUSHDEMON's Avatar
HAHAHAHAHA.... hilarious..
Good luck with your locks tho..
2003 Black H2:
2006 Blue H2:
Old 09-24-2009, 03:08 AM
HumminNBoatin''s Avatar
Sounds like a relay issue to me. All your door locks (excluding drivers door) should be on the same fuse and relay. Check your fuse panel first then your relays.
1998 Am General H1 HMCO
Eric@TheHummerClubInc.com
Old 09-25-2009, 01:54 AM
Thanks Boatn...I'll check it out this weekend...
Old 09-25-2009, 03:37 AM
porschett's Avatar
If I said it once, I'll say it again. Disconnect the battery, wait 10 minutes, reconnect and try it. Sounds wierd, but it fixes 90% of the electrical issues with these things.
2009 H2 Hummer It's here!!
2006 Baja Performance 88 MPH
2008 GT2 Porsche
2009 DBS
Old 10-02-2009, 12:20 PM
ardnamone ardnamone is offline
ardnamone is on a distinguished road
Talking Re: 2003 NOT Unlocking!?!?
Have the same problem with my 03 H2,there are two small black relays in the fusebox,remove the lower one,hit it gently a few times,refit and try again,works everytime,you will have to replace the relay with a new one sometime,but this trick can work for days.
