Old 09-23-2009, 03:49 AM
theBroken theBroken is offline
theBroken is on a distinguished road
Default H3 HEATED WIPER BLADES, GET READY FOR WINTER
DESIGNED, ENGINEERED, DEVELOPED AND MANUFACTURED IN THE USA
EVERBLADE WINTER HEATED WIPER BLADES WITH HEATED FRAMES.
Ive personally tested and helped make changes to these blades over the last year. After a few design and material changes these blades are ready for sale. They work great all year around and keep your blades from icing up in the winter. They will have the snow melted off them by the time your done warming up your hummer in the winter.
1 year limited warranty
To purchase simply email me at offroadtech@gmail.com with the subject EF EVERBLADE
Paypal and MO accepted, shipping is 15$ flat to the lower 48
The kit comes with everything you need to install
Refills available, these blades last a very long time and Ill have a price worked out before you need them.
Hummer H3
36 series kit
Kit with heated frames 108$ plus shipping
thats 12$ savings over MSRP
Replacement Blade Assemblies with Heated Frame for the 36 series are $40 plus shipping.
If you want the refill without the superstructure the its $35 plus shipping.
Install is easy, I hooked up the power wire to a blank non constant spot in my fuse box and ran the switch into the cab, check out the pictures.
36 series H3
Regular blade on the left EVERBLADES on the right
Pics of my install
Power from the fuse box
Through firewall for switch, you can do this anyway you want.
Knee plate comes down easy
This is the switch that comes in the kit, it has a light so you know when you have it on.
