Old 09-25-2009, 06:17 PM
jersey jersey is offline
jersey is on a distinguished road
Default How do you remove the headrests on an H3?
I purchased the Kenwood DVD/Nav in dash setup, but the dvd doesn't show on screen while driving. It has a 12 foot video out line to connect to rear monitors though and with that in mind I purchased dual headrest dvd monitors. The problem is I can't seem to remove the original front seat headrests. Is there a trick to it?
added info: It's an '06 H3 Cloth headrest.
Old 09-25-2009, 10:55 PM
Hummer Guy's Avatar
Hummer Guy is off the scale
Default Re: How do you remove the headrests on an H3?
There's a small hole near the base (the plastic piece that the headrest slides into) that you need to stick something in while pulling out. I use a small hex wrench.
-Brian
http://www.hummerguy.net
Old 09-26-2009, 06:51 PM
Much obliged Hummerguy...
Old 09-26-2009, 08:53 PM
NJ H2's Avatar
NJ H2 NJ H2 is offline
Jersey, which headrest monitors do you have?
Old 09-26-2009, 10:48 PM
fourfourto's Avatar
Jersey Im sure theres a way to get your dvd on when driving.
My eclipse uses the parking brake for the DVD to go on, the installer also hooked up a hidden switch .
If the switch is on Dvd will work.
If switch is off the parking brake must be on.
This way it apears to hooked up properly for insurance issues .
It might be wired to something else with your unit?.
Find the wire and hook up a switch.
