Old 10-13-2009, 12:05 AM
drmiles's Avatar
drmiles drmiles is offline
drmiles is off the scale
Default Front Diff Mounting Bolt
Ok I broke the bolt that holds the front Diff to the cross member does anyone have the exploded view so I can make sure I put all the washers and spacers back in the right place.
2007 H2
jerry
Old 10-13-2009, 01:16 AM
twr's Avatar
twr twr is offline
Default Re: Front Diff Mounting Bolt
hi this is for a 2008 h2 ,but i think a 2007 is the same. The torque for the rubber mount bolt is 63ft. lbs. Hope this helps
Old 10-13-2009, 01:33 AM
drmiles's Avatar
Yep thats the bolt. I think I have all the washers. I put a grade 2 bolt in it for now. Need to get Grade 1 I think.
Old 10-13-2009, 01:35 AM
drmiles's Avatar
Makes a damn awful clunking noise without that bolt.
Old 10-13-2009, 01:39 AM
twr's Avatar
twr twr is offline
hi drmiles, i bet it does, the diff can move alot without the bolt, i had mine apart but i don't remember the grade of the bolt. It may be best to get it from the hummer dealer.
Old 10-13-2009, 01:43 AM
drmiles's Avatar
Thanks, you don't have the part number as well?
Old 10-13-2009, 01:46 AM
twr's Avatar
twr twr is offline
hi sorry no i don't
Old 10-13-2009, 01:58 AM
drmiles's Avatar
Cool I'll bet the parts dept will
Thanks a lot
Jerry
Old 10-13-2009, 02:04 AM
twr's Avatar
twr twr is offline
Hi Jerry, your welcome. They will have the # just call them to see if its in stock.
Old 10-13-2009, 04:00 PM
HumminNBoatin''s Avatar
Should be able to pick it up from a hardware store. Its just a Metric grade 10.9 bolt with a flange nut head.
1998 Am General H1 HMCO
Eric@TheHummerClubInc.com
Old 10-16-2009, 06:00 PM
drmiles's Avatar
I Put a Grade 2 Bolt From tractor Supply. Bolt Say HKT on Top Not Sure if it is strong Enough.
Old 10-16-2009, 06:04 PM
drmiles's Avatar
Found this Guess I Need a Stronger Bolt!!
Bolt Grade Markings and Strength Chart
Head Marking Grade and
MaterialNominal Size Range
(inches)Mechanical Properties Proof Load
(psi)Min. Yield Strength
(psi)Min. Tensile Strength
(psi)US Bolts
No MarkingsGrade 2
Low or medium carbon steel
1/4 thru 3/455,00057,00074,000Over 3/4 thru 1-1/233,00036,00060,000
3 Radial LinesGrade 5
Medium Carbon Steel, Quenched and Tempered
thru 185,00092,000120,000Over 1 thru 1-1/274,00081,000105,000
6 Radial LinesGrade 8
Medium Carbon Alloy Steel, Quenched and Tempered
1/4 thru 1-1/2120,000130,000150,000Stainless markings vary. Most stainless is non-magnetic18-8 Stainless
Steel alloy with 17-19% Chromium and 8-13% Nickel
1/4 thru 5/8 40,000 Min. 80,000 – 90,000 Typical100,000 – 125,000 Typical3/4 thru 1 40,000 Min. 45,000 – 70,000 Typical100,000 TypicalAbove 1 80,000 – 90,000 TypicalHead MarkingClass and
(mm)Mechanical Properties Proof Load
(MPa)Min. Yield Strength
(MPa)Min. Tensile Strength
(MPa)Metric bolts
8.8Class 8.8
All Sizes below 16mm580640
800
16mm - 72mm 600660830
10.9Class 10.9
5mm - 100mm830940
1040
12.9Class 12.9
1.6mm - 100mm9701100
1220
Stainless markings vary. Most stainless is non-magnetic.
Usually stamped A-2
A-2 Stainless
Steel alloy with 17- 19% Chromium and 8-13% Nickel
All Sizes thru 20mm 210 Min.
450 Typical
500 Min.
700 Typical
Tensile Strength: The maximum load in tension (pulling apart) which a material can withstand before breaking or fracturing.
Yield Strength: The maximum load at which a material exhibits a specific permanent deformation
Proof Load: An axial tensile load which the product must withstand without evidence of any permanent set.
1MPa = 1N/mm2 = 145 pounds/inch2
Old 10-17-2009, 12:39 AM
twr's Avatar
twr twr is offline
Hi that bolt you are using is not good enough. Get a better bolt from the bolt supplier or go to the dealer and get the right bolt. That bolt also has a lock nut on it.
Old 10-18-2009, 02:40 PM
drmiles's Avatar
found a Grade 8 bolt. Seems to be the same as 10.9 if my mpa to psi calculations or correct.
