Old 10-17-2009, 06:53 PM
HummerRidin26"kmc's HummerRidin26"kmc's is offline
HummerRidin26"kmc's is on a distinguished road
Exclamation body roll when turning left
I have noticed recently when turning left my truck seems to body roll towards the right front tire,an i have also runined two diffrent toyo proxies on the right front alone.but feels very soild when making right turns. I have recently replaced both hubs,tie rods,pivot box,idlerarm,and pitman arm. does anyone have any suggestions on what else might cause this? All items where installed by hummer an alignments have been done by them aswell. The suspension just seems softer on the right side and the trucks only got 40k miles.
RickyFNRoss
Old 10-18-2009, 01:31 AM
Metallic Red's Avatar
Metallic Red Metallic Red is offline
Metallic Red is on a distinguished road
Default Re: body roll when turning left
Did they check your sway bar links?
Also check they sway bar at the ends, they crack sometimes..
Check the ride height from side to side, right side could be lower.
2004 Hummer H2 " Metallic Red "
20 inch Mojave's (Teflon)(325/60/20) BFG A/T's
MagnaFlow kitty back...Hypertech Tuned..Music to my ears
HCMI Member 50043
Old 10-18-2009, 05:34 PM
body mount?
Old 10-18-2009, 09:18 PM
worn out or blown shocks will also give you body roll.
2006 Yellow H2 Lux Series
Cognito Steering Support Kit
Cognito Idler Pivot Kit
Fabtech Steering Stabilizer
Fabtech Tie Rods
Power Slot Slotted Rotors
Hypertech Power Programmer
True Flow Foam Air Filter
