Old 11-03-2009, 05:42 PM
DuckTruck DuckTruck is offline
DuckTruck is on a distinguished road
Default EXACT Part # for the GREEN Torsion Bar KEYS???
Fellas,
Need some help.....
I did a search for the "green" keys (to go with my Cognito 3" front lift)...found a part number...ran it on gmpartsdirect.com...and the search came up with some part described as an "ARM"!?!
It does match the 22 dollar amount we are all aware of, but I wanted to see if anyone out there has recently made this purchase and could confirm the exact part # for me.
Thanks in advance!
DUCK
2003 H2, Lux & Adv Packages, Cognito 3" front suspension lift, Gobi Stealth Rack w/ Ladder, Navigation, twin Optima battery setup, AirRaid Intake, Granatelli Mass Air Flow Sensor, Flowmaster Big Block II Exhaust, Diablosport Predator Programmer,Cognito Pitman/Idler Arm Kit, Fabtech Tie Rods, Rancho RS 9000 shocks, Warn bumper and 9.5x winch, Warn light bar, PIAA's everywhere (14), everything blacked out, and rollin' on 39.5" Super Swamper IROKs on black powdercoated stock wheels.
Old 11-04-2009, 04:40 PM
Default Re: EXACT Part # for the GREEN Torsion Bar KEYS???
Anybody?
DUCK
Old 11-04-2009, 05:20 PM
SummitUp's Avatar
SummitUp SummitUp is offline
SummitUp is on a distinguished road
Chevy 1/2 ton green torsion bar keys:
GM Part # 15592573
Yes, the description comes up as "Arm" on the gmpartsdirect website. Don't worry, it's the correct part.
'05 H2 Lux, 37" KM2's on 17" Hutchinson Double Beadlocks, Cognito UCA's, Cognito Sway Bar Links, Custom Hydro-Assist Steering Upgrade, Eaton Front Differential Locker, 1" Rear Coil Spacers, Chevy Green Key Torsion Bar "Lift," Bilstein Shocks, Warn 9.5ti Multimount Winch, Dual Optima Yellow Top Battery's, Piaa & Hella Off-road lights, Gobi Rack, Tru-cool External Transmission Oil Cooler, Diablo Predator Hi-Octane Tune.
Old 11-04-2009, 06:18 PM
tomp's Avatar
tomp tomp is offline
In order to get the full 3" out of the front end, you will need different half shafts that allow for more flex or you will get bad vibration at 70+ MPH.
Cardone Select or RCV (available for H2 after next week) shafts are a good choice.
Old 11-04-2009, 06:22 PM
SummitUp's Avatar
So the RCV's will be available next week? How much $$?
I've emailed them twice inquiring about this and they never respond!
Old 11-04-2009, 08:32 PM
GM Part # 15592573
Thanks SummitUp.
DUCK
