Old 11-05-2009, 03:20 PM
BlackBullet BlackBullet is offline
BlackBullet is on a distinguished road
Default Trouble installing green keys.
Anyone have a hard time installing the green keys? I am not able to crank the torsion bars enough to slide the keepers in. The factory keys are easy enough to load but the green keys won't turn high enough to slide in the keepers. Also I will mention I am not using the torsion bar tool, I tried loading the key with a c clamp (I snapped the c clamp) then tried a bottle jack but wound up lifting the truck. So at this point I figure I need the tool which I can't find locally. Any input would be appreciated.
Old 11-05-2009, 05:48 PM
twr's Avatar
twr twr is offline
Default Re: Trouble installing green keys.
hi you need the tool if you are changing the keys here is a link for the tool http://www.readylift.com/p-65-gm-tor...ding-tool.aspx or maybe some other place has it cheaper. hope this helps
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
24 inch Starr 770 Hammer Rims
Gen 6 Lockpick
Gm bluetooth
Front + Rear Camera's
2005 Screamin Eagle, E Glide
http://twrbaggersplus.com/
Old 11-05-2009, 08:27 PM
badss98 badss98 is offline
badss98 is on a distinguished road
you can use a craftsman gear puller #46903 to remove and install keys as i did with no problems. Be warned that this is not the correct tool but will work just fine with caution.Do not use a smaller puller or you will put yourself in danger. The correct tool was in last post but this will save you some cash and do not be in a rush check the lips to make sure of positive contact with frame rail when tension is cranked and do not work directly underneath tool as there is allot of tension being applied to release keys.
2007 h2 lux,rear dvd,black,tinted windows,ventguards,flexfuel badges-HA HA ,chrome package,air ride,Front black brushguardand rear taillight guards,Invisible bra film3M
2007 h3 base,rear dvd,tinted windows,leveling kit,silver with painted stock wheels,carbon fiber hoodvent and lettering, Daily driver
Old 11-05-2009, 08:35 PM
HumminNBoatin''s Avatar
They will go in with the right tool. Thats How I did mine. A big impact gun will make it much easier to do as well. Are you sure your local autoparts store does not have one to rent?
1998 Am General H1 HMCO
Eric@TheHummerClubInc.com
Old 11-07-2009, 06:13 AM
Thanks for the feedback guys, I guess I will be ordering one soon.
