Old 11-24-2009, 12:42 PM
dealrocker dealrocker is offline
dealrocker is on a distinguished road
Default Popping sounds coming out.?
A friend of mine recently purchased a 07 H3 with Monsoon 6-disc changer. He noticed that popping sounds coming out from the speakers. He was told it may be an amp problem. Wondering the place where the stock amp is located and does anyone has the similar problem.
Any input will be helpful.
Old 11-24-2009, 02:26 PM
DAGKANA's Avatar
DAGKANA DAGKANA is offline
DAGKANA is on a distinguished road
Default Re: Popping sounds coming out.?
I believe the stock am is located next to the sub... its in the rear of the vehicle drivers side, the panel does pop off just got to convince it is all...
Are you sure it's not just white noise, and someone is trying to contact him from the otherside
315/75/16 Nitto Terra Grapplers on OEM black Powder Coated Rims/ Bilstein Cognitos w/ Trail Duty 1/2" Bump Stops/ BA Winch Bumper & Motoalliance Viper 12,000lb Winch/ Warn Hawse Fairlead / Manik Black Powder Coated Hood Handles/ Steelcraft Tail Light Guards/ Predator Motorsports Black Powder Coated Locking Fuel Door/ General Motors OEM Under Carriage Protection/ General Motors Rocker Panel Protection / BA Rear Shock Mount Skid Plates/ 60" Hi Lift Jack Extreme/
Old 11-25-2009, 06:35 AM
DC_Roller's Avatar
DC_Roller DC_Roller is offline
DC_Roller is on a distinguished road
Usually when you have popping noises, it means you may have a loose connection somewhere or crossed wires.
Old 12-05-2009, 05:48 AM
wannabeH3's Avatar
yeah amp is in the back next to sub, have fun getting to it. is it an aftermarket radio? if so then its probably the GMOS, or whatever cheap knock off they have installed. replace it with the expensive 130 dollar one and you will be good.
(with insurance)
