Old 11-24-2009, 06:04 PM
s_c5519's Avatar
s_c5519 s_c5519 is offline
s_c5519 is on a distinguished road
Default Hissing brake sound on '09
Truck has 2,000 miles on it, it's been doing it since I bought it. When I apply the brake there is a slight hissing sound coming from around the same area. It seems to go away if I press the brake 2 or 3 times or more immediately, but it does it every single time on the first press... Also I feel a tiny amount of feedback on the brake pedal when this sound happens...
Does anyone have an '09 and possibly an '08 and can check if yours does the same. I brought it to local Hummer dealer and 2 different people checked it out and said it was fine, that is normal, and they hear that on other different '09 vehicles. I forget what they said it was, but they said it was NOT a vacuum leak, which I was surprised to hear. I have had an '05 and an '07 and it definitely did not do it on those two, so I am guessing/hoping that is a normal thing on the newer H2's. The next closest Hummer service is about 50 miles away so I would rather not drive there for nothing too...
Old 11-25-2009, 12:48 AM
dvl57's Avatar
dvl57 dvl57 is offline
dvl57 is on a distinguished road
Default Re: Hissing brake sound on '09
initial squeeking sounds are normal on my 08 H2.
dealer said that's normal...and the brakes should last a long time.
Don
2008 H2
Billy Boat Exhaust
Old 11-25-2009, 01:07 AM
s_c5519's Avatar
dvl, are you getting a squeaking sound or a hissing, air sound? My sound is like an sssssssss... and it sounds like it's coming from the inside cab or firewall, not the outside brake pads...
Old 11-25-2009, 09:40 PM
twr's Avatar
twr twr is offline
hi my 08 doesn't make any noise inside when you hit the brakes. If you push the brake pedal with your hand with your head down there still no hissing noise. This only happens when you hit the brake?
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
24 inch Starr 770 Hammer Rims
Gen 6 Lockpick
Gm bluetooth
Front + Rear Camera's
2005 Screamin Eagle, E Glide
http://twrbaggersplus.com/
Old 11-25-2009, 11:57 PM
s_c5519's Avatar
Hi yes only with the brake. It just can't be normal, I will bring it somewhere else. Thank you for your replies.
Old 12-03-2009, 09:14 PM
s_c5519's Avatar
ok, looks like I have the answer?... I called the service dept at Legends Hummer in AZ and he said the hissing is normal and comes behind the firewall... The '09's no longer have the hydro booster that connects into the brake system. It is upposed to be a better setup. The ones ('08 and under)with the hydro booster would leak and make whining noise when turning...
Sound right? any brake experts here?
Old 01-02-2010, 05:52 AM
Saudi H2's Avatar
Saudi H2 Saudi H2 is offline
Saudi H2 is on a distinguished road
I have the same sound on my H2 sut 2009
When the brakes get warmer the kinda go away !
2009 H2 SUT Stock !
2006 H1 Alfa Wagon not stock
Can't wait to fix on some parts on it
