Old 11-25-2009, 09:02 AM
wingn69's Avatar
wingn69 wingn69 is offline
Default once again Optima batteries or ???
Okay I know this horse has been beat down many times on this forum. So I contacted Optima with the question and this is what I got back from them, find a forum and ask them. I'm adding lights and already have a lot of extras taken my juice. Remember I'm in Germany so no stop by auto zone or sears and pickup something please.
Unfortunately, Optima does not offer an exact-fit replacement battery for your Hummer. You can measure the dimensions of your existing stock battery to see if there’s an Optima that will work for your vehicle. Below is a link to the product specification page where you can find exact dimensions for all Optima batteries:
http://www.optimabatteries.com/optima_products/yellowtop/specs.php
http://www.optimabatteries.com/optima_products/redtop/specs.php
http://www.optimabatteries.com/optima_products/bluetop/specs.php
Alternately, you can check the internet enthusiast forums for your vehicle to see how others have done custom applications with Optima batteries.
[/font]
Old 11-25-2009, 01:05 PM
Easy Ed Easy Ed is offline
Default Re: once again Optima batteries or ???
Can try what DRTYFN did back in 2004, dual batteries
http://www.elcovaforums.com/forums/showthread.php?t=981&highlight=Optima+battery+inst all
Some more info on battery brands names and the actual manufacturer
http://www.elcovaforums.com/forums/showthread.php?t=37224&highlight=Optima+battery+in stall
Ed
Old 12-20-2009, 05:00 PM
wingn69's Avatar
Ok I went with a Kinetik HC2000 Power Cell fit in the factory location okay had to have a hold made to keep it in place but works.
Old 12-21-2009, 12:42 AM
splne1's Avatar
splne1 splne1 is offline
HAHA I have a Kinetik also!!!! but you didn't really need to go with the 2000 unless your using a lot of power! It's an audio battery and its model is relative to how many watts your system is drawing!!! I have a JL 1000 mono block amp and 3 12's im pushing with all the neon and strobe lighting. Thats why i went with the 2000 but you can easily do with the 1800.
Old 12-21-2009, 10:18 AM
wingn69's Avatar
Im happy for you.
I am still building on to my system and its better to have more than less. I have plans for more speaker, monitors and a light bar reason I went bigger than what I currently needed for your FYI. on the serious side how do you like yours and with all your stuff you have how long does it run?
Old 12-23-2009, 01:08 AM
splne1's Avatar
Believe it or not I replaced an Optima with my Kinetik!!!! I haven't had any problems at all!! I don't even need a capacitor connected to the amp. I have a 1 farad but I tell you even with out it my lights do not dim or flicker and I can finally have my stereo on for a while with the truck off without worrying about it not cranking over. Definently a great battery. I wouldn't be surprised if you could run a small onboard welder with it!!!
Old 12-23-2009, 09:17 AM
wingn69's Avatar
yeah yeah,
I do have 2x Rockford fosegate 10in subs in my rig that put out 130.1 db thank you, which is not bad if i say so my self with LED lights, KENWOOD DNX-7200, 2x 7in monitors and a 17 in monitor with the factory Bose and like i said I'm adding more speakers in the spring time and a light bar on top.
I have noticed my system plays much stronger now that the power level stays higher. Not sure if i would do a welder maybe a coffee machine.
Hey thanks for the info. I was going to go with two yellow top but it was more work to put them in when one Kinetik works even if i can power a small city .
