Old 12-06-2009, 01:40 AM
johndjmix1's Avatar
johndjmix1 johndjmix1 is offline
johndjmix1 is off the scale
Default Interior button lights
Little by little I have been losing the button illumination on my h2. First it was the diff lock then the 4 full time button under it. Now I have also lost the recurlate button on the climate control and the little gas pump and "I" button on the steering wheel
this seems odd for a 3 year old vehicle with only 40k miles. Any ideas? Anyone else notice similar bulb issues? Anyone got advice on getting the steering wheel buttons out so I can replace the bulbs?
--John
2006 Hummer H2 Lux Series
www.JohnHasMoreFun.com
1/4 Mile 15.29@91.34mph
Mods:
Warn 9.5 Winch
Old 12-06-2009, 01:44 AM
johndjmix1's Avatar
Default Re: Interior button lights
Interestingly enough my bulb in my boost gauge went out too. Now that's only a year or so old with only about 6000 miles on the truck since then. Weird. Possibly an over voltage condition? Where's the voltage regulator these days? Same as old school gm built into the altenator?(too lazy to look as it's snowing and raining here).
--John
Mods:
Warn 9.5 Winch
Old 12-06-2009, 11:36 PM
HumminNBoatin''s Avatar
I have had the same issues. Over time the bulbs go out and I just replace the buttons as the lights go out. The steering wheel ones are pretty easy to replace. Just get a small flat head screwdriver and pry them out. and CAREFULLY unplug the harness from the back of the switches. Its a short lead as well.
1998 Am General H1 HMCO
Eric@TheHummerClubInc.com
Old 12-07-2009, 03:00 AM
Luv2Camp Luv2Camp is offline
Luv2Camp is on a distinguished road
The best way to replace the switches is to remove the steering wheel first. Next remove the plastic cover on the backside of the steering wheel and you can now move the wire harness to each side as you pull the switches out. You will have more wire to work with and can pull the switch and the harness out a few inches this way. This eliminates the possibility of braking the plastic retainer on the switch and makes it really easy to install the new one.
Also, it is best to use a small curved pick and push the switch out from inside of the steering wheel versus prying it out (or use a visegrip and pull the switch from the area that sticks up between the buttons when they are depressed. I have seen some of these steering wheels split when someone tries to pry the switch out. The area around the switch is just foam....
Old 12-07-2009, 03:11 PM
Yeah your method is probably involves allot less risk but is much more time consuming. So if you are a novice at working on Auto Interiors the Luv2camp is no doubt the way to go.
However I used to install car stereos professionally while in highschool and know my way around interiors pretty well.
Old 12-11-2009, 02:13 AM
johndjmix1's Avatar
Doesnt removing the wheel involve airbag issues? Ive installed superchargers, done suspensions, but never removed an airbag. Help!
--John
Mods:
Warn 9.5 Winch
Old 12-11-2009, 03:28 AM
RCKSTR's Avatar
RCKSTR RCKSTR is offline
RCKSTR is on a distinguished road
the diff lock button on my 03 does not light up.. is it supposed to? The other lights for the transfercase burnt out, took about an hour but I got it apart and soldered new bulbs onto the board...
_____________________________________________
2003 H2 w/ adventure package,4" Rancho lift, 20" cruiser alloys, Blacked out, 7" In dash DVD, Wood Kit, Billet chrome handles
