Old 12-25-2009, 07:34 AM
twenty2's Avatar
twenty2 twenty2 is offline
Default MAF Sensor
I have a 03 rig.. Has anyone ever had to change their MAF sensor? I have a code that reads that... In prior posts, I thought my battery was going dead,but since then, I havent had a problem.... But, when I drive with my heat on, my truck idols lower than normal and tends to die. When I took it in to get the engine light checked, it showed MAF sensor...
Old 12-25-2009, 10:29 PM
NJ H2's Avatar
NJ H2 NJ H2 is offline
Default Re: MAF Sensor
Before you replace the MAF, try cleaning it and throttle body with Carb Cleaner.
Old 12-31-2009, 07:37 PM
Marauder Marauder is offline
Marauder is on a distinguished road
Definitely use MAF specific cleaner. I am not sure but I would assume carb cleaner will damage the elements in the MAF.
I am sure carb cleaner would be fine on the throttle body if you had some laying around. But they also sell throttle body specific cleaner as well. A lot of the application specific sprays are based on what film or particles each of the sprays will leave behind.
Old 12-25-2009, 10:31 PM
splne1's Avatar
splne1 splne1 is offline
Try some maf sensor cleaner from autozone or pepboys if there out electronics cleaner will work. Cleaned mine out and cleared my light. I tend to get some K&N oil on mine most of the time!!!
