Old 12-27-2009, 06:14 PM
lt.rain lt.rain is offline
lt.rain is on a distinguished road
Question cognito motor sports 2002 - 2007 Hummer H2 Pitman and Idler Arm Support System
what's up brothers .. has anyone had the pleasure of dealing or has anyone heared anything about it..H2 Pitman and Idler Arm Support System by cognito.. i have an 04 supercharged h2.. 39,000 on it and was looking to replace the whole steering system with heavier duty parts... please guys need another head on this ... where to buy .. what to buy. thanks.....
Old 12-27-2009, 07:03 PM
splne1's Avatar
splne1 splne1 is offline
Default Re: cognito motor sports 2002 - 2007 Hummer H2 Pitman and Idler Arm Support System
Use the search feature there are plenty of posts on cognito!!
Old 12-27-2009, 10:33 PM
Wink Re: cognito motor sports 2002 - 2007 Hummer H2 Pitman and Idler Arm Support System
http://www.trailduty.com/
has all the parts you need
2006 Yellow H2 Lux Series
Cognito Steering Support Kit
Cognito Idler Pivot Kit
Fabtech Steering Stabilizer
Fabtech Tie Rods
Power Slot Slotted Rotors
Hypertech Power Programmer
True Flow Foam Air Filter
Old 01-08-2010, 07:13 PM
Hammer Hammer is offline
Hammer is off the scale
Post Re: cognito motor sports 2002 - 2007 Hummer H2 Pitman and Idler Arm Support System
my questing is it worth it. I have lifted truck and steering wear is excessive I can drive it like 5000 miles and thats it... This support kit is supposed to reduce wear and make the steering feel more firmer, does it work?
Old 01-09-2010, 01:35 PM
How are you driving it that you're wearing it out in 5K miles?
I put over 50K on my first lifted H2 and almost 10K on this one and both drive like factory.
Other than Cognito upper control arms and Fabtech tierod ends (which is a needed mod) the front ends are stock.
Mark
Old 01-09-2010, 07:09 PM
Astroboy Astroboy is offline
Astroboy is on a distinguished road
Shouldn't this Cognito kit work with my 08 too?
Isn't the design of steering system the same all years of H2s?
I want to know because I was just about to order this kit from Cognito.
I heard this was the common problem with all of GM's previous 2500HD trucks (H2 being one of them). And one is advised to install this kit to prevent inevitable failures with said weak tie rods even for the H2s in stock form.
