Old 12-17-2002, 12:01 AM
TonkaH2 TonkaH2 is offline
TonkaH2 is off the scale
Well, maybe not LIFE-saver, but certainly paint-and dent-saver: those little stick on "wide-angle" mirrors you can buy in any auto accessory area.
If you get the ones the are offset and can revolve [that is, they have a back that offsets the mirror at a slight angle] then you can aim them. Do it just right and you can not only see someone in your blind spot, you can also see your rear tires. I've found the best spot is the outermost bottom corner, away from the car. They don't block much viewing area that way.
VERRRY helpful when you can't go any farther forward and have to crawl back out. And you'll never run over a curb while parking again!
-Jack
Yellow H2 adv. on order
"I think I can make it. D'OH!"
sunspotnatural.com
yellow H2 adv.
