Old 01-10-2010, 02:05 AM
theBroken theBroken is offline
theBroken is on a distinguished road
Default FS: 2 hummer H3 shelf style winch plates. NEW 350$ +shipping
350$ shipped! lower 48 only
QUICK NOTE:
Was test fitted with mile marker 8000 and 9000 PE winches. I'm unable to try every winch to make sure it will fit all of them. I would like to but you will have to do your own research for the winch you have. If you need a winch contact me about that but its not included in the price.
I got 2 for sale both exactly the same and new. Will accept standard winches and both hawse and roller style fairleads. Has holes in the fairlead mount angles for strapping down or locking your winch cover. Also a pre-drilled hole on the plate for a flag or light. Included is the spring and hardware for a flag whip.
They are "new". They were only used for testing, fitment and strength. We have the next and final design drawn up in the computer but we need to sell these to start development on the next version.
Key features:
5/16" steel plate
Main plate is a single piece rolled not welded connections
Vibration/thermal pads on all connection surfaces to keep standing water away.
Works with oem brushguard
Powercoated black then finished with 2 coats of line-X
Keeps winch high out of road grime and water.
Very heavy duty
< OEM SPEC approach angle
Mounts with OEM hardware
EXTRA VIBRATION PADS IF YOU NEED THEM
HERE IS WHAT IT LOOKS LIKE INSTALLED. THIS WAS A DIFFERENT ONE WE DID BUT IT GIVES YOU A IDEA OF WHAT IT LOOKS LIKE INSTALLED.
Old 01-11-2010, 01:37 AM
Default Re: FS: 2 hummer H3 shelf style winch plates. NEW 350$ +shipping
Getting a few questions so I thought I would answer them publicly too. The advantage to the shelf style winch plate is that you keep your winch exposed and very high up on the H3. This keeps it out of the mud and away from damage. It also will keep your winch clean in a bad mudhole. When you go into the mud and start sinking the plate pushes water and mud out of the way so if you need to use it you won't have to dig it out like the hidden winch systems ex: the BA bumper and DOI winch system.
Yes I will take offers but I can't go too low. These are test models so they cost a bit more than if I had 10 of them made at one time.
The spring is removable along with the hardware. The spring is just if you need it for a flag whip. You may never use it. You can also put a light with a 3/8" stud in that hole for a extra light. I use to run mine rite off the winch power.
Here are dome more photos I found. These are not the two I have for sale exactly but they are previous test models we made and sold over the last year.
Old 01-11-2010, 10:23 PM
1 LEFT
The last one to help sell it I will include a milemarker roller fairlead. Rollers are rusty but the rollers spin free and smooth. You will need your own hardware for the fairlead.
