Old 02-09-2010, 04:22 AM
Default Electronic lockers.... how to do rear?
Here's my dilemma....
Because you can lock in the rear axle on a stock H2 from the factory switch, electronic lockers are available only for the front.
Now that my H2 is getting the diesel conversion, I won't have the same 4WD system. It will lock in like a regular silverado.
I'm sure you can buy electronic lockers for a silverado but do they have the same 12 bolt rearend that the H2 has?
I'd like the ability to lock in all 4 wheels if I wanted.
Anyone enlighten me on this?
Mark
Old 02-09-2010, 05:42 PM
HumminNBoatin''s Avatar
Default Re: Electronic lockers.... how to do rear?
Why don't you just use your factory rear diff? You can buy and eaton e-locker for any GM and it should work right off of your stock TCCM.
1998 Am General H1 HMCO
Eric@TheHummerClubInc.com
Old 02-09-2010, 06:12 PM
I am using my factory rear diff. The problem is the controls on the dash is what allows you to lock in the rear axle, right? Well, I won't have those controls any longer, it will be like a normal 4WD. (ie. chevy)
Mark
Old 02-10-2010, 04:40 PM
Mark, you will have a new selelctable transfer case with rear locker! They should have no issue making that work for you. The guy up the road from me has the deisel conversion and he has the factory rear diff, locker, and button to engage it. You should also be able to upgrade the front to an Eaton and have an additional switch to that as well. Call Predator and tell them to run a seperate switch for your rear locker. ...should NOT be an issue.
Old 02-10-2010, 05:36 PM
Thanks Tim,
Sounds like it should be exactly what I wanted. I'll call and check into now.
Thanks, MUCH APPRECIATED!!!
Mark
