Old 09-03-2004, 02:14 AM
Klaus's Avatar
Klaus Klaus is offline
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD><TITLE>Service Information</TITLE>
<META http-equiv=Content-Type content="text/html; charset=iso-8859-1">
<META content="Microsoft FrontPage 5.0" name=GENERATOR></HEAD>
<BODY bgColor=#ffffff>
<FORM name=topNavForm action=/servlets/CellHandler>
<TABLE width="100%" align=center>
<TBODY>
<TR>
<TD width="25%" slign="LEFT"></TD>
<TD align=middle width="50%">Document ID# 841961 </TD>
<TD align=right width="25%"></TD></TR></TBODY></TABLE>
<HR>
</FORM>
<H1>Noise in Steering Column</H1>
<TABLE width="100%" border=1>
<TBODY>
<TR>
<TH vAlign=bottom align=middle>
Step</P></TH>
Action</P></TH>
Yes</P></TH>
No</P></TH></TR>
<TR>
<TD vAlign=center align=middle><A name=S01>
1</P></A></TD>
<TD vAlign=top align=left>
Did you review the Steering Wheel and Column Description and perform
the necessary inspections?</P></TD>
<TD vAlign=bottom align=middle>
Go to Step2
</P></TD>
Go to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=65643&RefDoc=841961&evc=sm">Sym ptoms
- Steering Wheel and Column</A> </P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S02>
2</P></A></TD>
Verify that noise is present in the steering column during
operation.</P>
Is noise present in the steering column during operation?</P></TD>
Go to Step3
</P></TD>
System OK</P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S03>
3</P></A></TD>
Inspect the steering column components for looseness.</P>
Is the steering column components loose?</P></TD>
Go to Step10
</P></TD>
Go to Step4
</P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S04>
4</P></A></TD>
Inspect the SIR coil for noise.</P>
Is the SIR coil noisy?</P></TD>
Go to Step11
</P></TD>
Go to Step5
</P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S05>
5</P></A></TD>
Inspect the horn contact ring for lubrication.</P>
Is the horn contact ring lubricated?</P></TD>
Go to Step12
</P></TD>
Go to Step6
</P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S06>
6</P></A></TD>
Inspect the lock plate retaining ring for the correct installation.</P>
Is the lock plate retaining ring installed properly?</P></TD>
Go to Step13
</P></TD>
Go to Step7
</P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S07>
7</P></A></TD>
Inspect the shaft bearing for the following conditions:</P>
<UL type=BULLET>
<LI>Damage
<LI>Lubrication
<LI>Wear
<LI>Proper seating </LI>[/list]
Are the bearings in need of repair or replacement?</P></TD>
Go to Step14
</P></TD>
Go to Step8
</P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S08>
8</P></A></TD>
Inspect the spherical joint for lubrication.</P>
Is the spherical joint lubricated?</P></TD>
Go to Step15
</P></TD>
Go to Step9
</P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S09>
9</P></A></TD>
Inspect the steering column coupling for looseness.</P>
Is the steering column coupling loose?</P></TD>
Go to Step16
</P></TD>
Go to Step3
</P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S10>
10</P></A></TD>
Tighten the steering column components to specifications. Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=58777&RefDoc=841961&evc=sm">Fas tener
Tightening Specifications</A> .</P>
Did you complete the repair?</P></TD>
Go to Step17
</P></TD>
--</P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S11>
11</P></A></TD>
Replace the SIR coil. Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=57781&RefDoc=841961&evc=sm">Inf latable
Restraint Steering Wheel Module Coil Replacement</A> in SIR.</P>
Go to Step17
</P></TD>
--</P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S12>
12</P></A></TD>
Lubricate the horn contact ring.</P>
Go to Step17
</P></TD>
--</P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S13>
13</P></A></TD>
Install the lock plate retaining ring properly.</P>
Go to Step17
</P></TD>
--</P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S14>
14</P></A></TD>
Repair the shaft bearings as necessary. Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=70056&RefDoc=841961&evc=sm">Tur n
Signal Cancel Cam and Steering Shaft Upper Bearing Spring Replacement</A>
and to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=68501&RefDoc=841961&evc=sm">Ste ering
Column Shaft Replacement</A> .</P>
Go to Step17
</P></TD>
--</P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S15>
15</P></A></TD>
Lubricate the spherical joints.</P>
Go to Step17
</P></TD>
--</P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S16>
16</P></A></TD>
Tighten the steering column coupling to specifications. Refer to <A
Go to Step17
</P></TD>
--</P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S17>
17</P></A></TD>
Operate the system in order to verify the repair.</P>
Did you correct the condition?</P></TD>
System OK</P></TD>
Go to Step3
</P></TD></TR></TBODY></TABLE>
<FORM name=bottomNavForm>
<HR>
<TBODY>
<TR>
<TD align=right width="25%"></TD></TR></TBODY></TABLE></FORM></BODY></HTML>
Klaus's Avatar
<TBODY>
<TR>
<HR>
</FORM>
<TBODY>
<TR>
Step</P></TH>
Action</P></TH>
Yes</P></TH>
No</P></TH></TR>
<TR>
1</P></A></TD>
Go to Step2
</P></TD>
Go to <A
<TR>
2</P></A></TD>
operation.</P>
Go to Step3
</P></TD>
<TR>
3</P></A></TD>
Go to Step10
</P></TD>
Go to Step4
</P></TD></TR>
<TR>
4</P></A></TD>
Go to Step11
</P></TD>
Go to Step5
</P></TD></TR>
<TR>
5</P></A></TD>
Go to Step12
</P></TD>
Go to Step6
</P></TD></TR>
<TR>
6</P></A></TD>
Go to Step13
</P></TD>
Go to Step7
</P></TD></TR>
<TR>
7</P></A></TD>
<UL type=BULLET>
<LI>Damage
<LI>Lubrication
<LI>Wear
Go to Step14
</P></TD>
Go to Step8
</P></TD></TR>
<TR>
8</P></A></TD>
Go to Step15
</P></TD>
Go to Step9
</P></TD></TR>
<TR>
9</P></A></TD>
Go to Step16
</P></TD>
Go to Step3
</P></TD></TR>
<TR>
10</P></A></TD>
Go to Step17
</P></TD>
--</P></TD></TR>
<TR>
11</P></A></TD>
Go to Step17
</P></TD>
--</P></TD></TR>
<TR>
12</P></A></TD>
Go to Step17
</P></TD>
--</P></TD></TR>
<TR>
13</P></A></TD>
Go to Step17
</P></TD>
--</P></TD></TR>
<TR>
14</P></A></TD>
and to <A
Go to Step17
</P></TD>
--</P></TD></TR>
<TR>
15</P></A></TD>
Go to Step17
</P></TD>
--</P></TD></TR>
<TR>
16</P></A></TD>
Go to Step17
</P></TD>
--</P></TD></TR>
<TR>
17</P></A></TD>
System OK</P></TD>
Go to Step3
<HR>
<TBODY>
<TR>
Klaus's Avatar
<TBODY>
<TR>
<HR>
</FORM>
<TBODY>
<TR>
Step</P></TH>
Action</P></TH>
Yes</P></TH>
No</P></TH></TR>
<TR>
1</P></A></TD>
Go to Step2
</P></TD>
Go to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=65643&amp;RefDoc=841961&amp;evc =sm">Symptoms
<TR>
2</P></A></TD>
operation.</P>
Go to Step3
</P></TD>
<TR>
3</P></A></TD>
Go to Step10
</P></TD>
Go to Step4
</P></TD></TR>
<TR>
4</P></A></TD>
Go to Step11
</P></TD>
Go to Step5
</P></TD></TR>
<TR>
5</P></A></TD>
Go to Step12
</P></TD>
Go to Step6
</P></TD></TR>
<TR>
6</P></A></TD>
Go to Step13
</P></TD>
Go to Step7
</P></TD></TR>
<TR>
7</P></A></TD>
<UL type=BULLET>
<LI>Damage
<LI>Lubrication
<LI>Wear
Go to Step14
</P></TD>
Go to Step8
</P></TD></TR>
<TR>
8</P></A></TD>
Go to Step15
</P></TD>
Go to Step9
</P></TD></TR>
<TR>
9</P></A></TD>
Go to Step16
</P></TD>
Go to Step3
</P></TD></TR>
<TR>
10</P></A></TD>
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=58777&amp;RefDoc=841961&amp;evc =sm">Fastener
Go to Step17
</P></TD>
--</P></TD></TR>
<TR>
11</P></A></TD>
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=57781&amp;RefDoc=841961&amp;evc =sm">Inflatable
Go to Step17
</P></TD>
--</P></TD></TR>
<TR>
12</P></A></TD>
Go to Step17
</P></TD>
--</P></TD></TR>
<TR>
13</P></A></TD>
Go to Step17
</P></TD>
--</P></TD></TR>
<TR>
14</P></A></TD>
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=70056&amp;RefDoc=841961&amp;evc =sm">Turn
and to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=68501&amp;RefDoc=841961&amp;evc =sm">Steering
Go to Step17
</P></TD>
--</P></TD></TR>
<TR>
15</P></A></TD>
Go to Step17
</P></TD>
--</P></TD></TR>
<TR>
16</P></A></TD>
Go to Step17
</P></TD>
--</P></TD></TR>
<TR>
17</P></A></TD>
System OK</P></TD>
Go to Step3
<HR>
<TBODY>
<TR>
