Old 02-14-2010, 06:54 PM
SnoopFogg's Avatar
SnoopFogg SnoopFogg is offline
SnoopFogg is on a distinguished road
Default Aftermarket DRL wiring
I've searched around and found hints at how to do this but no step by step so... I 've mounted a set of aftermarket 55 watt halogen DRLs that have their own harness and switch to mount on the dash. I would rather wire them so that they function like the OEM DRLs so I don't have to worry about switching them on and off. Does anyone know how to do this?
Thanks!
Old 02-15-2010, 12:54 AM
twr's Avatar
twr twr is offline
Default Re: Aftermarket DRL wiring
hi to have them hooked up like the DRL they will not be on at night. Is that what you want?
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
24 inch Starr 770 Hammer Rims
Gen 6 Lockpick
Gm bluetooth
Front + Rear Camera's
2005 Screamin Eagle, E Glide
http://twrbaggersplus.com/
Old 02-15-2010, 05:33 AM
SnoopFogg's Avatar
I have done the DRL mod that lets them come on at night. I just need to know at what point to have the new harness splice into the existing DRL wiring and not have to use the manual switch that came with the new 55 wat DRLs.
Old 02-15-2010, 03:26 PM
twr's Avatar
twr twr is offline
Hi the best way is to install a fused relay harness and let either side left or right of DRL control the relay. Using the pos wire from the DRL plug run to the + control side of the relay. This will let them work with no manual switch. Hope this helps.
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
Gen 6 Lockpick
Gm bluetooth
Old 02-15-2010, 04:00 PM
SnoopFogg's Avatar
That is exactly what I needed! Thanks!
Old 02-15-2010, 04:15 PM
porschett's Avatar
I'm far from an expert on this, but if you want them to work like stock, what's wrong with cutting the wires at the factory lights and splicing them to the new lights?
2009 H2 Hummer It's here!!
2006 Baja Performance 88 MPH
2008 GT2 Porsche
2009 DBS
