Old 03-05-2010, 09:18 AM
prideandufc's Avatar
prideandufc prideandufc is offline
prideandufc is on a distinguished road
Default HVAC HELP !! any techs on this forum??
I have owned my 2008 H2 since new and the front of the hvac controls were totally rubbed off (plus and minus) I took it in to the dealer and they replaced it but now my heat when set to max 90degrees is nowhere near as hot as it used to be. BUT the laser temp gauge still registered above ninety when I took a reading at the dealership with the tech. I don't care what he says that **** use to blow SUPERHOT when on max and now its barely hot when your hand is closest to vent. He says he owns a silverado pickup and its the same thing with his. I don't give a **** WHAT he says I know for a fact also because my fiance also noticed that it wasn't as hot anymore. I know these have to be calibrated to match the vent opening and digital temp number. Is the internal vent NOT opening all the way even though the digital number says 90??
I ****ing knew it !!! If I took it in they would **** IT UP. AND to boot my AUX vents in the back seat area and cargo area don't blow ANYTHING AT ALL.
what gives is their anything I can do myself. That way they wont **** anything else up????
Old 03-05-2010, 05:23 PM
MVR 155's Avatar
MVR 155 MVR 155 is offline
Default Re: HVAC HELP !! any techs on this forum??
Bring it back.... ask to have a different tech work on it..... if not try a different dealer
1/4 mile: 11.661@118.86
2013 Audi S4
2002 Yamaha YZF R1 Blue/White
1/4 mile: 10.51@136
2005 Sea-Doo RXT
Old 03-08-2010, 04:04 PM
pdsq99f4 pdsq99f4 is offline
Maybee there is a different program in the new control head. The dealer could check to see if there is an updated program of codes in the controler. I don't think I would go in with an attitude though.
Old 03-09-2010, 02:18 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
I would make sure they programmed the control head and after that that you need to do an actuator recalibration procedure with the tech 2 scanner. If these are not done it may not function properly
1998 Chev Z71
2007 Chev Trailblazer SS
