Old 03-15-2010, 11:46 PM
pdxrealtor's Avatar
Default OEM Roof Cross Bars and the RUBBER STRIP!
What the hell am I doing wrong here?
I don't see how it's possible to insert the rubber strip that goes across the top of the cross bar...
Can someone give me some tips??
2006 HUMMER H2
MOOG Front End
Diablo InTune w/DiabLew Tune
Cognito Steering Support
OBX LT Headers
Air Raid Filter w/Tube
Corvette Servo
Rancho Steering Stabilizer
Viper Smart Start
iPod/Video Interface
HID Head and Fog Lights
Old 03-16-2010, 01:01 AM
Luv2Camp Luv2Camp is offline
Luv2Camp is on a distinguished road
Default Re: OEM Roof Cross Bars and the RUBBER STRIP!
If you spray the back side with some wd40 (around the rubber area that has the groves, you can start at one end and slide the strip all the way across to the other side. If you have any spots that stick up, you can hit it down with a rubber hammer but should have no issues sliding the way I just described. If you do not want to use WD40, you can also use a little dish detergent in warm water. If you can soak the strips in hot water as well it will help make them more plyable
Old 03-16-2010, 09:51 AM
Olfart's Avatar
Olfart Olfart is offline
Olfart is on a distinguished road
Might want to try Silicone Spray instead of WD-40 which can damage rubber parts
2004 Black H2
Old 03-16-2010, 04:51 PM
pdxrealtor's Avatar
Thanks. I tried soap and water and that helps but not enough to get the strip all the way through.
Does anyone just leave the strips out??
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
Old 03-25-2010, 08:06 AM
SmokeyJoe's Avatar
SmokeyJoe SmokeyJoe is offline
SmokeyJoe is on a distinguished road
I just did 5 this past weekend. Some went easy, while others were difficult. I sanded the bar down with some 200grit. Then, since it was cold I soaked the in hot water soapy water. I put some soap directly on the bar, and with a spray bottle kept it wet. All but one slid one, after I got it about half way I had to lift the one end about 8 inches and pull it the rest on the way. Then I pushed and beat the leftover 8 inches with an rubber mallet.
Good Luck.
Old 03-25-2010, 05:13 PM
pdxrealtor's Avatar
Good Luck.
Thanks.... I just gave up.
If it is that much of a pain when the bars are on my saw horses there's no way I'm dealing with it while they're on my roof.
Maybe one day when I get board I'll pull them out and mess with them!
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
Old 03-25-2010, 07:44 PM
Patience, all it takes is a little patience....
....and a whole lot of cussing.
Mark
Old 03-25-2010, 08:12 PM
pdxrealtor's Avatar
I've only got one of those two qualities....
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
Old 03-25-2010, 08:42 PM
Old 04-02-2010, 02:16 PM
Crush'em's Avatar
Crush'em Crush'em is offline
Crush'em is on a distinguished road
Bought new rubber strips for my roof rails last week, left the strips in the sun for about an hour, sprayed soapy water on the rails, and they slid all the way on, easy-pleasie
2007 Hummer H2 Yellow SUV
37"x13.5"x20" Toyo Open Country MT's, 20x10 Method Racing 301's, Fox 2.0 Performance Series Shocks, Truxx Level kit, color matched grill, (Almost) all chrome removed, Removeable U-steps, Factory All weather mats, Gobi flip-up front plate, Factory brush guard
