Old 03-23-2010, 07:52 AM
SmokeyJoe's Avatar
SmokeyJoe SmokeyJoe is offline
SmokeyJoe is on a distinguished road
Default Light Bar OEM
I was wondering if anyone had direction to installing the in vehicle light bar wiring harness?
Old 03-24-2010, 02:36 AM
Default Re: Light Bar OEM
If you have an '05 or older, you can go to the dealer and ask them for the OEM light bar wiring harness from an '06 or newer.
It's a short harness that connects the light bar to the factory wiring. Now, you won't have the end connector but you can splice it into the factory harness (you just need power and ground)
The reason you want the factory harness is because it comes with the switch and makes it that much easier. (not a MUST have but a WILL help)
HTH's,
Mark
Old 03-24-2010, 08:36 AM
SmokeyJoe's Avatar
Thanks, I just bought the harness, but was needing the directions.
Old 03-24-2010, 02:11 PM
Joe,
Sorry man, I misunderstood. If I remember correctly, you really shouldn't need any instructions. The harness on one end plugs into a factory plug and the other end just gets spliced in.
You have to run it down the A pillar and into the dash for the switch.
Of course, at my age, my memory is only half as long as my dick.
Mark
Old 03-25-2010, 02:34 PM
SmokeyJoe's Avatar
Thumbs up Re: Light Bar OEM
Bump
