Old 03-27-2010, 09:02 PM
theBroken theBroken is offline
theBroken is on a distinguished road
Default Hummer H3 frame plate support plate 65$ shipped
These 3/8" frame plates are not a replacement but a add on to the existing weak frame plates on the H3. Located behind the D-hook mounting plates in the front are the existing frame plates. These plates are what your hooks, winch plates, bumpers and brush guard are held up with. They are thin and deform under heavy loads from winching and using your hooks for recovery. Once the existing plates deform they are greatly weakened. The new frame plates weld onto the back of the existing plates creating a stronger and much safer system to mount your winches to. Use of your hooks without worry of failure is greatly increased too.
65$ shipped to mainland US locations
Key features-
-Water jet cut
-CAD designed
-Cut from 3/8" structural steel
-Easy to follow instructions included with purchase
-Can be easily installed by any muffler shop
Email me if you would like a set offroadtech@gmail.com
