Old 04-24-2010, 04:12 PM
BLUETHUNDER BLUETHUNDER is offline
BLUETHUNDER is on a distinguished road
Default Does this sound like an ignition switch problem???
I was out and about yesterday afternoon. Stopped off to pick something up. Returning to the hummer,i blipped the fob for the remote start and nothing!!. Couldnt even hear the fuel pump engage. I got in and turned the key manually and nothing. No click from the starter or the fuel pump priming.
I have all the electrics. Dash lights,headlights etc working. Turning the key doesnt even dim the headlights prior to it starting. Now ive noticed from the owners handbook that there is what looks like two ignition switches in the fuse board. Checking on the Rockautos site and typing in ignition switch the picture shows something different. Is there a seperate switch located in the steering housing or somewhere else on the vehicle???.
Old 04-25-2010, 06:31 AM
bbtcorp bbtcorp is offline
bbtcorp is on a distinguished road
Default Re: Does this sound like an ignition switch problem???
check your fuses...had one blow the other day...same problem and turned out to be a fuse under the hood is was one of the bigger ones 40amp green, you will be able to see if its blown by just looking at it through the clear glass
Old 04-25-2010, 12:25 PM
Thanks for your help.
Old 05-02-2010, 01:28 AM
Well. It did indeed turn out to be a 40 amp fuse. Thanks for the tip.
