Old 05-09-2010, 02:49 AM
Xotik H3 Xotik H3 is offline
Xotik H3 is on a distinguished road
Default Door chime volume way to high
Does anyone know of a way to reduce or otherwise adjust the volume of the door chime? I have an 03 H2 and the chime is crazy loud. Thanks
Old 05-09-2010, 04:10 AM
The_Yeti's Avatar
The_Yeti The_Yeti is offline
The_Yeti is on a distinguished road
Default Re: Door chime volume way to high
I think there's an option in the Menu that you select on the steering wheel. Cycle thru there there's quite a few things you can change.
Old 05-09-2010, 04:18 AM
LEcustoms's Avatar
LEcustoms LEcustoms is offline
LEcustoms is off the scale
I don't believe you can change the door chime volume.
"A clear conscience is usually the sign of a bad memory."
03 White H2
12 HID lights, factory lightbar, custom light bar for brush guard, OEM luggage rack, k&n intake, Gran MAF, 37" Toyo M/T's, 17x12 weld racing wheels, predator programer, Dynomax 4" catback exhaust,
02 10th Anniversary H1 #44 Will be missed
94 Custom pearl white H1(work in progress)
Too many mods to list
06 kawasaki stx-15f
02 yamaha superjet
02 polaris scrambler 500
Old 05-09-2010, 05:44 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
there is a reflash for the radio for this concern. If the radio has been replaced they may have programmed it wrong.
1998 Chev Z71
2007 Chev Trailblazer SS
Old 05-09-2010, 06:15 PM
rmutchler's Avatar
rmutchler rmutchler is offline
rmutchler is on a distinguished road
My 06 has an option in the touchscreen radio to adjust the volume of the chime...not sure if the 03 has the same?
Old 05-11-2010, 01:52 AM
At least it isn't one of those easy questions. I don't have the touch screen - regular radio with CD.
Old 06-14-2010, 02:47 AM
Scarsman's Avatar
Scarsman Scarsman is offline
I agree. My '05 is WAY loud! I doubt the radio has been replaced though. Is the reflash a TSB or something?
Mirror caps - black bedliner
Old 06-14-2010, 10:58 AM
HoeHum's Avatar
HoeHum HoeHum is offline
HoeHum is on a distinguished road
I have an 04 with 6 CD changer. Mine was cranking loud. This worked to fix it.
Chime Level Adjustment
The radio is the vehicle?s chime producer. To change
the volume level, press and hold pushbutton 6 with
the ignition on and the radio power off. The chime
volume level will change from the normal level to loud,
and LOUD will appear on the radio display. To
change back to the default or normal setting, press and
hold pushbutton 6 again. The chime level will change
from the loud level to normal, and NORMAL will appear
on the radio display. Removing the radio and not
replacing it with a factory radio or chime will disable
vehicle chimes.
