Old 05-19-2010, 01:59 AM
Default Compatibility view for Firefox...help?
When I was using IE, I had to use "compatibility mode" to view posts on Elcova.
When I switched to Firefox, I have the same problem I had with IE before using the "compatibility mode".
The problem was when you try to respond to a post for instance, there is a HUGE gap between the top of the page and the respond dialog box.
When you click on the compatibility mode button, it eliminates that gap.
Hope I explained that correctly...anyone have any suggestions?
Thanks,
Mark
Old 05-20-2010, 04:16 AM
NEGATE's Avatar
NEGATE NEGATE is offline
NEGATE is off the scale
Default Re: Compatibility view for Firefox...help?
I had that same problem too. I think I went under the "view" tab, then zoom and then hit reset. Not sure if that was all that was needed but what a pain in the rear. Good luck.
