Old 06-04-2010, 01:23 AM
ggammariello ggammariello is offline
ggammariello is on a distinguished road
Default '07 H3 Starting Problems
Ok, I have brought my truck into two different Hummer Dealers, and a Chevy dealer. No one can find an issue with out. At random times when I go to start it I hear a metal on metal clanking noise and the turck struggles to start. There is no pattern to when it happens, both winter and summer, hot or cold start. The last time I brought it in they stated that my starter bolts were very loose and said tighented them and it should be fixed, but a week later its back to the same sounds. I have attached some recordings, let me know what you think.
Old 06-13-2010, 03:54 AM
jrbnc jrbnc is offline
jrbnc is on a distinguished road
Default Re: '07 H3 Starting Problems
Interesting. I have the same sound on your #3 recording, on my 2009. Mine keeps trying to start without actually kicking over for a few seconds. But I don't get any of the clanking in your other recordings. Mine is also completely random maybe once a week it will happen. I hope someone knows a fix.
Old 07-06-2010, 12:42 AM
signals34 signals34 is offline
signals34 is an unknown quantity at this point
sounds like the starter is going...
Old 07-06-2010, 01:32 AM
I was able to narrow it down to after driving longer than an hour. I recorded it happening and took it to the dealer. They found a bunch of error codes related to the ignition switch. They replace it and so far so good. Keeping my fingers crossed.
Old 07-06-2010, 01:08 PM
HummerJim's Avatar
X2 Sounds like the starter to me too.
Old 07-15-2010, 05:05 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Unplug your crank sensor and check for oil contamination. Check your ecm connectors for coolant contamination. Just fixed one that had both. Messed me up after the crank sensor didnt repair the whole problem and found coolant in ecm connector.
1998 Chev Z71
2007 Chev Trailblazer SS
