Old 06-07-2010, 01:47 AM
seanflood seanflood is offline
seanflood is on a distinguished road
Default Sunroof humming....
My 06 H2 SUT sunroof humms at speeds greater than 55. I thought at first it was my sunroof air deflector, so I removed it. It wasn't that. Is this normal? It doesn't leak any water. My warranty runs out in 27 days.
Old 06-07-2010, 02:05 AM
Easy Ed Easy Ed is offline
Default Re: Sunroof humming....
Sure it is the sunroof ?
Might be the window molding http://www.elcovaforums.com/forums/s...ad.php?t=16756
Ed
Old 06-08-2010, 01:45 AM
Yeah, I had a buddy listen for it. It was definetly from the sun roof.
Old 06-08-2010, 02:17 AM
Intercooled's Avatar
Intercooled is off the scale
Check all the rubber moldings on the sun roof exterior.
I had a Humm this past spring and it was a dried up leaf stuck in near the corner marker light . The leaf would Hum, buz at when i got on the high way. I finally got out a ladder and discovered the leaf.
2006 H2 SUT Fusion Orange LE
Old 06-09-2010, 01:34 AM
I got a ladder out and cleaned the sunroof channel out completely. It still makes the humming sound. Thanks for the advice though.
Old 06-09-2010, 02:35 AM
PHATBOYPIMP PHATBOYPIMP is offline
PHATBOYPIMP is off the scale
I bet Ed is right. We have all been through this little experiment....
Old 11-02-2010, 02:23 PM
Mark Morrison Mark Morrison is offline
Mark Morrison is on a distinguished road
I am going through the same thing. I removed the deflector and that did not cahnge anything. I do notice that at speeds around 60, my sunroof vibrates slightly near the front of it. I believe that the movement is causing noise. Anyone else notice this?
