Old 06-19-2010, 12:49 AM
charto911 charto911 is offline
charto911 is on a distinguished road
Talking Can any GM mechanic work on a H1?
Was looking at purchasing an H1 and wanted to know if any GM dealership can work on the H1 or if it takes a special mechanic. Also is there a listing of local mechanics that can work on Hummers? Finally hopefully you will see pics of a soft top convertible 1998+ soon!!
Old 06-19-2010, 03:18 PM
oilyocean oilyocean is offline
oilyocean is on a distinguished road
Default Re: Can any GM mechanic work on a H1?
I use a local gmc dealer and they most of the time can work on it--so far they have replaced a condensor for the ac and the injection pump.
Old 06-20-2010, 01:52 AM
Camou2 Camou2 is offline
Camou2 is on a distinguished road
IMO absolutely not! Most GM dealers that sold Hummers never had a certified H1 mechanic. There are some good H1 mechanics around. I would take the time to call AM General and see if they can tell you where you can find H1 service in your area.
www.thehummerclubinc.com
2004 H1 Softtop
2006 H2
2008 H3 Alpha
Old 06-21-2010, 01:09 AM
BACKNBLACK's Avatar
BACKNBLACK BACKNBLACK is offline
BACKNBLACK is off the scale
X2 and then some!!! FIND A CERTIFIED H1 MECH AT ANY COST!!!!
CURRENT HUMMER:
Number# 11 2007 H3x Desert Orange
SOLD BUT NOT FORGOTTON
1995 H1 350 HT GAS Black
2001 H1 Open Top Black
2004 H2 SUV Yellow
2004 H2 SUV Black
2005 H2 SUT Black
2006 H3 ADV Black
2006 H3 ADV RED
2008 H2 Black/Sedona
2009 H3T Alpha Solar Flare
Old 06-23-2010, 07:18 AM
ssgharkness020147's Avatar
Unless you are looking at a truck under warranty, I say avoid the dealer at any cost. The simple fact of the matter is even when HUMMER was in its heyday the number of COMPETENT H1 techs across the country were not that high.
Here's the simple and honest truth: You are talking about buying a truck that hasn't been made in four years, the number of HUMMER dealers that even have an H1 tech on staff today is virtually non existent (barring a few). Hell, there are hardly any stand alone HUMMER dealers left!
The engine is a standard GM 6.5 G series engine (found in GM vans)
The trans is a 4L80-E (found in heavy duty trucks of that era)
The transfer case is a standard NP242 and is not harder to service or rebuild that any other chain driven transfer case
The diffs are AMC 20 variants they are a little unique, but nothing a competent tech cant service, and there are a couple of great guys to get remans from should you ever need a new one. Same goes for the brakes, half shafts, yeah its different... So what its simple.
The geared hubs are unique and most people won't want to touch them. If you have a bearing failure of something that warrants opening it up there are a few highly recommended people throughout the US for you to send them too for rebuilding.
The HVAC system is largely based of a GM, any HVAC shop can work on it.
CTIS, that one scares everyone. I'll tell you a little secret though.... It is VERY easy to fix when there is a problem.
See what I'm getting at here? The truck is a mutt as far as parts go, alot of which are GM (never mind the steering column that came out a a ford escort), most of which are not that special, or any harder to work on than any other truck. The long short of it is yes your GM dealer should be able to service your truck. Ask them if they have a Hunter alignment rack, if they do they should absolutely be able align your truck. Tire balancing can be harder to find, most shops cant balance a 37 + inch tire, a local 4x4 shop should be able to help you out there.
Buy the beast, if you are happy with your local GM dealer take it there for service, and buy your HUMMER specific parts/accessories from www.rubberduck4x4.com. Travis @ RD4x4 is a standup guy to buy from, he'll find you what you need for the most fair price out there, and he's a fun guy to talk with. Good luck 911, where are you located anyways.
1997.5 Black Slantback
The Sole Remaining God Father
-007=
Old 06-23-2010, 03:28 PM
HummerJim's Avatar
Every time I have been to Lynch to pick up a part in the last three weeks, there have been at least five and sometimes more H1s being serviced. IMHO they know H1s the best. Maybe that's one reason you see so many H1s in Missouri?
Old 06-23-2010, 05:58 PM
Lynch is a place I would absolutely have service my truck and one of a few dealers that has proper techs on staff. They've always lived and died with the H1.
-007=
