Old 06-24-2010, 02:10 AM
seanflood seanflood is offline
seanflood is on a distinguished road
Default Installing DVD Headrest
Has anyone installed there own OEM DVD headrest? I have a 2006 H2 SUT and about to receive OEM DVD headrest with wire harness. I am wondering if the connection already exist under the seats or will I have to splice into the wires. Thanks for any feedback.
Old 06-24-2010, 08:20 PM
H2FAR's Avatar
H2FAR H2FAR is offline
H2FAR is on a distinguished road
Default Re: Installing DVD Headrest
I did mine on Monday. You are talking about the boulder accessory unit correct? Everything is plug and play..you route the wires through the seatback and into the center console, that's where the dvd player is and all connections route to that. The hardest part is fishing the wire from the headrest down through the seat using a coathanger to pull a wire through and using that to yank the video cable through. I can tell you how I did it but someone else might have a better idea there.
2005 H2 Lux Stealth Gray w/body color grill
2004 SL55 AMG
2005 SSR 6 speed
2009 R350 4matic
1999 Suburaban LT 2500 4wd SOLD
Old 06-25-2010, 01:57 AM
H2FAR, thanks for the info. This system has the dvd player in each monitor. I'm not sure what the boulder accessory unit is. The pioctures showed cables from each headrest. I should be receiving it by tomorrow and was trying to be ahead of thegame by getting info now so I can attempt this install over the weekend.
