Old 06-26-2010, 08:30 PM
todbusa todbusa is offline
todbusa is on a distinguished road
Default Any help would help...Need drivers seat(module)
Heres where i stand...03 h2 w/78k lux...driver seat has died...went to dealer and after 3+hrs there they info me that i need a new driver side module...did the reprogramm...nothing...so they want 521.94 for the module...yea...so does anyone know where i could get one for less...found 1 for 309.00+shipping... looking for less then that...thanks for all the help...
71 Chevy C10 P/U.
97 Vette C5..
03 H2...
03 Busa....
Old 06-26-2010, 10:42 PM
Easy Ed Easy Ed is offline
Default Re: Any help would help...Need drivers seat(module)
This help ? Correct one ?
Memory module, hummer h2 03-06 MSRP $228.17 Your Price $135.26
Electrical - Body electrical - Power seats - Memory module
http://www.gmpartsdirect.com/catalog...TOKEN=68939413
Ed
Old 06-27-2010, 07:29 PM
Hey ed that does help... but why is the dealer trying to sell me a 2007 module for a 03 h2????...What a price diff...521.94 for a 07 only...when a 03 is 228.17 new for a 03-06 h2...and there is no price for a 08-09 module...thank again for your help...
71 Chevy C10 P/U.
97 Vette C5..
03 H2...
03 Busa....
Old 06-27-2010, 07:55 PM
HUMTECH might have more answers for you as to why they wanted to sell you a 2007 if he comes on and reads this. The price has gone down since I bought mine a couple years ago, not sure why but mine was $268.64 ?? Just a FYI, they can be a pain to install
Ed
P.S. Damn, just looked at the 2007 module and have no idea why it cost so much ??? Maybe they had one "on the shelf" and wanted to sell it ? Wouldn't think it would work though since the other one is for the 03 through 06 and that would be the one you want not one for a 2007 ???
Good luck, Ed
Old 06-27-2010, 08:04 PM
ED did your seat lock up too...if so what did u go with... a 07 module or 03?? thanks todd
p.s no they had to order it with payment in full to do so...(NOT)
71 Chevy C10 P/U.
97 Vette C5..
03 H2...
03 Busa....
Old 06-27-2010, 08:24 PM
My heated seats quit working and I had no adjustment for the drives seat. I put the one in (guess it was a revision part) for my model year, 2003. I lied also, just checked the invoice and it was in 2006 that I replaced it, my bad on guessing 2008
Here is the post I had on it http://www.elcovaforums.com/forums/s...ad.php?t=21588 and I guess the FAQ I mentioned in the post no longer exist
Also, I cannot find the part number 15288527 mentioned on any of the parts sites ???
Old 06-27-2010, 09:57 PM
So that would mean that u had an 03-06 module installed...right...the gm tec told me to find one on ebay or somewhere and he would put my vin in it so it would work for my trk...but he gave me part # 15835069 module 15283117 and thats for a 07 h2...???i think if i get a 03-06 module they come empty and need set up...thats what he told me...my heated seat still works but the seat is locked(module)so it will not move back for me...little hard to drive it locked in wifeys spot...shes 5'3"125 me 6'4" 300lbs...fat guy in a locked seat...thanks for all of your help ed...
71 Chevy C10 P/U.
97 Vette C5..
03 H2...
03 Busa....
Old 06-27-2010, 10:09 PM
Mine didn't need programed, was "plug and play" ya could say
Might try to PM the member on here called HUMTECH and see what he says, he nows his sh!t
Good luck, Ed
Old 07-01-2010, 08:13 PM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
PM sent. as for the newer module the older one may not be available from gm anymore, likely has changed up but not sure.
1998 Chev Z71
2007 Chev Trailblazer SS
Old 07-01-2010, 08:18 PM
HUMTECH's Avatar
Also try disconnecting the memory seat module for about half an hour(module under the seat) plug it back in and give it a try.
1998 Chev Z71
Old 07-03-2010, 03:55 AM
I did every thing under the sun...And then some more...GM tried...dead...Just going to buy a new one from somewhere...
71 Chevy C10 P/U.
97 Vette C5..
03 H2...
03 Busa....
Old 10-10-2010, 04:35 PM
Default Re: Any help would help...Need drivers seat(module)...
OK... So Heres the update...After months of searchs here is what I did to fix my drivers seat...Went to GmPartsDirect.com ...Got part#15835070 Module 03-06H2...w/shipping & taxes came to 164.50...not too bad,Gm wanted 521.00 just for the module...so i order it this last week, it was here on fri...Now here comes what i thought would be the biggest pain in the ass...removing the drivers seat...Started on Sat morning took off side cover of seat,and you guessed it ..my seat was stuck over the bolts on the left side...sooo now what...seat will not move...so started to look around for other bolts that i could remove...under the front of the seat i found 2 nuts that holds the bottom of the seat to the base...took them of...and guess what...i did not have to remove the drivers seat after all ...i was able to get to the module from the top...2 nuts 2 screws 4 plugs later and of course the new module...bam my seat is working again...finally...I hope this helps someone else down the road...A Thank u goes out to Easy Ed and HumTech for responding to my thread...
71 Chevy C10 P/U.
97 Vette C5..
03 H2...
03 Busa....
Old 02-22-2012, 03:18 AM
myfender myfender is offline
myfender is on a distinguished road
Ok I appreciated the tip about the two nuts on the seat!!! I got my module out 15835069 is the part number for my 06 with heated memory seats. passenger heat doesnt work (doesnt light up) and none of the controls or heat work on the drivers seat. I tried disconnecting battery, circuit breaker and module for 2 hrs, plugged it all back in, no work.
You said you bought the 15835070 which is a ton cheaper $150 vs $400 (cheapest I could find for the 15835069). Did you have heated seats because what I can tell is the 69 is for heated seats and the 70 is without......want to get this working as my seat is tilted back right now. I did try and replace the circuit breaker figure $16 is worth a try first.
The TSB says if it works after a unplug then replace the module as it has a memory lockup and says keep troubleshooting if it doesnt work after unplugging.
Do I pay the $100 diagnostic fee to Chevy service in hopes that it is a bad wire somewhere or are they just going to tell me to replace the modlue and charge me $570?
Thanks,
Sean
06 h2
