Old 06-30-2010, 07:53 PM
Scarsman's Avatar
Scarsman Scarsman is offline
Default Sway bar disconnects?
Does anyone run sway bar end link disconnects? I know they are pretty common practice on other IFS rigs used offroad.
I tried searching on here and didn't really find anything. Does no one use them? None made for us?
Mirror caps - black bedliner
Old 07-05-2010, 08:32 PM
Scarsman's Avatar
Default Re: Sway bar disconnects?
Hmmm. Well, it seems this is uncharted territory. Maybe when I get the time I will do some experimenting and see if it would offer any benefits.
Old 12-07-2010, 08:42 PM
slippy slippy is offline
slippy is on a distinguished road
iv seen people tip toe around this and im hoping one day someone will check it out. measure full droop with the sway bar connected and disconected, to see any xtra travel. If there is (which i assume there is) you could get a fab shop or whip up some disconects. Then if you want to go all out look into mounting the shock higher up and puting in longer shocks and adjust bumpstops for even more down travel.
solid axles are easy and if i had springs i would have already done it but since i have airbags iv been putting it off.
