Old 07-06-2010, 05:59 AM
surf twang surf twang is offline
surf twang is on a distinguished road
Default Resetting Avg. Fuel Economy
We ended up buying the 2006 Pacific Blue Limited Edition (pictures forthcoming). I'm trying to reset the Average Fuel Economy but I don't know if I'm actually doing it correctly. The Owner's Manual says to press and hold the select button for one second. Is the value supposed to be reset to zero? It stays the same for me.
Thanks.
Old 07-06-2010, 06:06 AM
Default Re: Resetting Avg. Fuel Economy
Never mind, I figured it out.
Old 07-06-2010, 06:21 AM
seventwozero's Avatar
seventwozero seventwozero is offline
seventwozero is on a distinguished road
2004 white H2 SUV lux
Old 07-06-2010, 08:33 AM
Olfart's Avatar
Olfart Olfart is offline
Olfart is on a distinguished road
Why don't you share what you did. Might benefit others in the forum with the same question.
2004 Black H2
Old 07-06-2010, 10:21 AM
With the Avg economy visable in the info center, press and hold the select button for 1-2 seconds, the counter will reset to 0.0
Old 07-06-2010, 01:15 PM
HummerJim's Avatar
I rarely reset the mpgs unless on vacation, but I reset the gallons used with the <__] steering wheel button every time I fill up.
Old 07-07-2010, 12:31 AM
Intercooled's Avatar
Intercooled is off the scale
Also works to reset the oil life %. I reset after each oil change.
2006 H2 SUT Fusion Orange LE
Old 07-07-2010, 09:27 PM
I followed instructions...
Old 07-07-2010, 11:30 PM
Olfart's Avatar
My 2004 doesn't reset to zero using instructions here....holding down Select button...so thought you might have tried something else
2004 Black H2
