Old 07-11-2010, 05:41 PM
TOAST TOAST is offline
TOAST is on a distinguished road
Default Need help unlocking/open trunk/rear door
I have looked thru the forum and went on the search to see if anyone has had this happen but couldn't find anything. I have a 07 H2 and this morning I went to open the trunk/rear door and it wouldn't unlock when I used the key fob and so I tried using the unlock button inside the truck and it still wouldn't unlock. Since there isn't a key cylinder on the rear door to unlock it with a key how do I get the rear door open? Any help would be appreciated. Thanks in advance.
Old 07-11-2010, 05:49 PM
jarek m's Avatar
jarek m jarek m is offline
jarek m is on a distinguished road
Default Re: Need help unlocking/open trunk/rear door
Off goes the inner paneling.
Missing the times when things where made to last.
Old 07-11-2010, 06:20 PM
I tried to do that but can't take it off unless the rear door is open.
Old 07-12-2010, 02:26 AM
jarek m's Avatar
Ok, here are your two access points.
One from the out side held in place with snap ins. But it wouldn't make much sense to be able to open a lock car from the outside.
And then there is the inside panel that CAN come off with the door closed at the expanse of this two plastic stubs.
Old 07-12-2010, 04:59 AM
Ok I'll try that. Thanks.
