Old 07-12-2010, 10:59 AM
kalantar kalantar is offline
kalantar is off the scale
Default My 04 H2 factory extended warranty is coming due, what should I check for?
Knock on wood, my h2 has been extremely reliable and for the most part trouble free. My factory extended warranty is coming up 1/2011 but I am taking it now because the front bearings seem to be going bad again and is making horrible noises. Hopefully this will be the last time I use the warranty, what else should I tell them to check for? I was also told my drive shaft is a bit loose when they tug on it. Mirrors seem to vibrate a bit as well (not sure if this is covered under extended factory warranty). What are common things that go out on the h2 with 70k miles on it?
Old 07-12-2010, 11:23 AM
twr's Avatar
twr twr is offline
Default Re: My 04 H2 factory extended warranty is coming due, what should I check for?
Hi get them to check all the front end parts tie rods, ball joints, idler arm, pitman arm, both drive shafts ujoints and oil leaks. Also make sure your AC is working correct all of these items can be costly to fix.
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
24 inch Starr 770 Hammer Rims
Gen 6 Lockpick
Gm bluetooth
Front + Rear Camera's
2005 Screamin Eagle, E Glide
http://twrbaggersplus.com/
Old 07-12-2010, 08:31 PM
seventwozero's Avatar
seventwozero seventwozero is offline
seventwozero is on a distinguished road
To add to the list above mine had leaking front axle seals, a broken exhaust manifold bolt and cracked oil cooler lines (causing a leak).
2004 white H2 SUV lux
Old 07-12-2010, 08:59 PM
Olfart's Avatar
Olfart Olfart is offline
Olfart is on a distinguished road
Here's what was done to my 2004 H2 Lux since I purchased it used in 2006. Luckily I bought a 3 yr ext warranty for about $1000...which has now expired.
36,821 miles
12/15/06 ? 37,600 - Battery
3/12/07 - 38,256 ? Castrol GTX 5W30 oil ? filter ? wiper blades
3/18/07 - Replace Wiper Motor ? Warranty
5/17/07 - 39,555 - Rotate tires
10/17/07 ? 40,690 ? Oil, Filter, Lube
10/23/07 ? 40,861 ? Air Filter Element ? Update OnStar
5/1/08 ? 42,660 ? Oil, Filter, Lube
11/20/08 ? 45,382 ? Oil, Filter, Lube
2/3/09 ? 45,777 ? Warranty ? Repair Shifter Wire ? Replace Water Pump and Belt
5/19/09- 47,048 ? Oil,filter,lube
7/21/09 ? 48,120 ? Warranty ? Steering Pump and Pressure Valve, Front End align, Ex Manifold broken bolts, Remove Head, Pitman and Idler arms worn.
New Tires and front end alignment.
12/10/09 ? 49,846 - Oil, filter, lube. Hood support cables rusted.
3 yr ext warranty now expired
12/14/09 ? 49,857 ? Eng temp inst. stepping motor bad. Inst Cluster sent to be rebuilt
6/18/10 - 51,999 - Oil, Filter, Lube ? 50,000 mi service
Replace leaking front axle seals
I also sealed up leaking Marker Lights and repaired my 6 CD Player when a CD broke inside it....never play CD's when 4 wheeling
When I bought it in 2006 the outside mirrors had already been replaced with the updated version. Don't know what else had been done to it.
Alot of repairs, but hopefully that's all for a while. Luv this damn truck
2004 Black H2
Old 07-16-2010, 08:11 PM
Awesome.... thanks
Old 07-31-2010, 11:56 AM
Just an update, turns out the front end was shot from bearings, to idler arms, pitman arms, etc. I guess this why my Toyos wore down 1/4 inch for only 3k miles. The extended warranty finally payed off.
