07-14-2010, 11:17 AM
Help! Remote start stopped working.
Remote start has been working fine till this morning. Two blips on the lock button on the fob should engage the remote start. But all i get is the fuel pump clicking in and then nothing. Trying to unlock the Hummer with the remote fob does nothing. I have to enter the car manually with the key. Inserting the key in to the steering coloum and turning off,and there is a delay of between 5-10 seconds before the engine shuts off. Restarting with the key seems to sort the problem.
Funny thing is,i fitted a pair of l.e.d tailights last night. Surely that couldnt interfere with the circuit?????.
Any help guys.
07-14-2010, 11:26 AM
Re: Help! Remote start stopped working.
hi is it a factory remote start or aftermarket?
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
24 inch Starr 770 Hammer Rims
Gen 6 Lockpick
Gm bluetooth
Front + Rear Camera's
2005 Screamin Eagle, E Glide
http://twrbaggersplus.com/
07-14-2010, 01:42 PM
I have no idea. How would i be able to tell?
07-14-2010, 03:13 PM
From what I understand LED lights draw less power and can reek havoc on the H2's electrical system. I would try to remove them and see what happens.
07-14-2010, 10:28 PM
Sounds like maybe the VATS module for the remote starter has gone bad. If it is an older remote, some of the first generation bypas modules could "creep" out of the correct resistor range. May need a trip to your local alarm/remote shop. Find out who your local hummer dealer sends theirs to...
07-15-2010, 06:49 AM
Thats what i find strange. Is that once the fob is into remote start mode,i then cant do anything else with the fob. It will not respond to me opening the doors or shutting off the engine. I have to get in to the car manually through the door lock. Pressing the foot brake without the key in the ignition used to cut the engine off. Now it keeps running when i do the same. I have to put the key in the barrel,turn the ignition on,then off,and wait 5-10 secs for the engine to cut out.
I will try putting the old lights back on and see if that makes any difference. Regarding a Hummer dealer. We have no dedicated Hummer dealers in the UK.We have many specialised American car dealers who will cover a vast range of american cars from Hummers,other SUV,s Trucks Camaro,s Vette,s Mustangs and Challengers etc. American cars in the UK are sold to a very niche market. And its not that big do warrant U.S companys setting up dealerships here. The only official dealerships here are Jeep and . But they are set up for selling the Nitro,300c And Jeep. And are totally hopeless at proper built U,S stuff. G.M sells the small chevy volt through the Vauxhall dealerships here. But thats it.
07-17-2010, 02:45 AM
Check for a wire splice into the data link connector under dash left side purple wire. Sounds like aftermarket remote start creating a problem on the data line. If there is a splice there attempt a remote sart then measure the voltage from that wire to ground. Key off should be 0. Key on it should toggle between 0 and 5 volts, wont see those numbers exactly but it should change up and down. If its solid 5v or higher your remote start module is creating a voltage spike on the data line.
1998 Chev Z71
2007 Chev Trailblazer SS
07-19-2010, 06:18 AM
iff your engine light is on the remote start will not work, check for that?
