07-15-2010, 07:45 PM
VortecMax L76
I figured I'd throw this out there and see what feedback I get...
I've been 'thinking' about a Duramax conversion for my '05 when I hit 150,000...I'm only at about 80,000 now, so I've got a ways; but I've read through some horror stories on the forum about this, and I hate to ask how much Predator is charging now...
SO...that got me thinking about what would make a more friendly upgrade...something without as many ECM, wiring problems, etc.
In researching the Vortec line of engines I noticed that the 4th Gen Vortec 6000 (L76 - VortecMax) has an 'aluminum block.' Hmmmm...(thinking...thinking)...my science teacher, Mr. Reader, told us that aluminum is 'lighter' than iron...(thinking...thinking)...if the engine weighs less, the truck weighs less...if the truck weighs less, the engine doesn't have to work quite as hard to move the truck...if the engine doesn't have to work as hard my performance and mpg should go up.
I couldn't find exact specs on the LQ4 or the L76...so I don't know the actual weight difference, nor do I know if the L76 would bolt up to everything that it needs to bolt up to...so I thought I'd put this out there and see if anyone had any additional thoughts or information.
CNTRY
DTOM
07-15-2010, 10:28 PM
Re: VortecMax L76
LQ4 = 520 LBS
L76 = dont have a answer for this
i doubt it is going to weight less than 100 to 150 lbs than the LQ4.
while weight does help with the power, your going to need to free up alot more weight than just that of the motor to even feel a difference.
could drill the body, and any other sheetmetal to cut out soem weight.
drop the tires to some low profile hit a speed bump and take out your differential tire.
some high end rims.. do they make titanium rims yet? thats going to be light!
right now with my 20 inch rockstars, and 37 inch BFG MT tires, im sure the weight is over 100 lbs per tire/rim
take the spare out of the back
take off the roof racks
/shrug
07-15-2010, 10:34 PM
Re: VortecMax L76
Just a thought...I would love to have a Duramax, but am just worried about the project becoming a nightmare.
I've already dropped all of what I consider 'unnecessary' weight...roof rails, side steps, 60 side of the rear 60/40 seat, and the third row. But then I've prolly added just as much with the Boulder Accessories front bumper/winch and the OEM rear tire mount and the BFG 37 Mud Terrains.
CNTRY
DTOM
07-15-2010, 11:09 PM
Re: VortecMax L76
so you only have one seat besides the front two?
07-16-2010, 12:34 AM
Re: VortecMax L76
Yes and no...I still have my third row seat (when needed)...sounds crazy, huh? Well, not entirely crazy. There is a method to the madness...
I removed the 60 half of the seat...not for weight-reduction but to create a hidden storage area. The bottom of the seat (the bit that you sit on...or used to sit on) is completely gone.
The back of the seat (the bit that had the headrest, arm rest and cup holders) I removed, stripped down to the metal frame, sprayed it with undercoating (to make it black...and because it had a bit of surface rust), and re-attached the carpet to the back-side of it. I then put it back in the truck using the same mounting points. When lying flat (as it always is) it is completely indistiguishable from the original configuration.
I use the storage area (which boasts about eight/nine inches of clearance...I never measured) to stow gear that I otherwise would have needed to mount in a location that was visible and/or would have cluttered up my console and glove box (walkies, jumper cables, flash lights, machetes, tool kit, tire iron, and high-jack).
The area also serves as a good mounting point for the on-board PC that I installed to replace the factory nav/radio. The PC, wiring, and peripherals all mount to the bottom side of the metal seat-back; keeping it in a semi open-air environment and off the floor to avoid any possible water damage should I wander too far into a creek that is too deep. I've also mounted my fire extinguishers on the plate too.
Couple that with the fact that in the four/five years I've owned the truck I've never had the need to transport more than three other passengers (I guess I'm just not a people person), AND that I plan on keeping this truck until one of us dies...it seemed like a solid choice to meet my needs.
Besides meeting my personal needs, another thing I like about this configuration is that when loaded with four passengers, the rear passengers are one behind the other, which leaves my cargo area as one contiguous block of space. This works out good because the only time I ever have four people in the truck is if we're going camping and this allows us to store our gear in a smart manner. Plus I think it weirds people out being in that seating configuration...which adds to the perceived 'adventure' of just being in a Hummer.
So...not crazy...just whittling it bit by bit into the truck that I need.
CNTRY
DTOM
08-21-2010, 03:21 PM
Re: VortecMax L76
Aluminum LS series blocks are roughly 80ish lbs lighter than the FE blocks.
Hybrid Mode
