Old 07-20-2010, 12:36 PM
The_Yeti's Avatar
The_Yeti The_Yeti is offline
The_Yeti is on a distinguished road
Default Installing rear corner bumpers 88966142 RH AND 88966141 LH??
I've just purchased rear corners/lights and harness for my 03. I was wondering if anyone has replaced or installed these before. I'm looking for some info on how to remove the originals. I've seen some info on removing the center HUMMER piece any info would be appreciated.
I bought the pieces on eBay if anyone else is looking to add
Item number: 290423411874
Old 07-24-2010, 11:20 PM
The_Yeti's Avatar
Default Re: Installing rear corner bumpers 88966142 RH AND 88966141 LH??
Well I got them installed.
I thought I'd share incase anyone wanted to or needed to remove their rear corner pieces. I started on each side of the center HUMMER piece with 2 flat head screw drivers. There are 2 push pins on each side. Once you get those undone. Start from the top and safely but firmly start pulling. Technically you don't have to remove the center but I found it easier when doing the rest of the work. Each corner has 3 pins(the kind that you pull the center out of then the base) Once these are out there is only one clip attaching the corner to the bumper. I just gave it a pull and it was off. The toughest part was removing the plug to connect the harness. Its been connected since 2003. with the center piece off you can see the plug clearly. Took about an hour to complete.
I purchased the corner the harness and the lights from the same seller on eBay.
HARNESS 88966140 ebay Item number: 290429611230
Rear Corners Item number: 290423411874
He doesn't have an auction for the lights but did let me know he had some. Or you can get the LED ones.
Old 07-25-2010, 06:19 PM
vetteSUT's Avatar
vetteSUT vetteSUT is offline
vetteSUT is on a distinguished road
Looks good! Now you can go out and take care of those zombies that keep eating everyones brains!
I like your tires btw. What kinda/size?
Old 07-25-2010, 09:17 PM
The_Yeti's Avatar
Nitto Extreme Mud Grapplers. I love them but boy are they noisy!! I'll probably go with the KM2's when it's time to change up.
Old 07-26-2010, 11:14 AM
vetteSUT's Avatar
Well, nice looking truck nonetheless!
