Old 09-10-2010, 08:44 AM
SmokeyJoe's Avatar
SmokeyJoe SmokeyJoe is offline
SmokeyJoe is on a distinguished road
Default Rear Lift Blocks
Hello,
I just ordered 1.5" spacers for the rear of my Hummer. Can anyone tell me the best way to install these. I have only installed them on leaf springs before.
Thanx
Old 09-10-2010, 10:54 AM
twr's Avatar
twr twr is offline
Default Re: Rear Lift Blocks
Hi lift the truck up put it on jack stands under the frame and with the jack under the diff lift the jack up abit to take some of the weight off so you can undo the lower shock bolts shocks. Then start to lower the jack till their is some clearance at the coil spring to install the blocks. After the blocks are installed jack the diff back up and reinstall the shock bolts. Now lift the truck up and remove the stands and lower the truck back on the ground. It takes about 20 mins to do hope this helps.
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
24 inch Starr 770 Hammer Rims
Gen 6 Lockpick
Gm bluetooth
Front + Rear Camera's
2005 Screamin Eagle, E Glide
http://twrbaggersplus.com/
Old 09-10-2010, 01:06 PM
SmokeyJoe's Avatar
Thanx a bunch, even easier than leaf spring blocks
Old 09-10-2010, 04:05 PM
twr's Avatar
twr twr is offline
Hi glad I could help
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
Gen 6 Lockpick
Gm bluetooth
Old 09-10-2010, 06:45 PM
splne1's Avatar
splne1 splne1 is offline
You may need to disconnect the panhard bar to get it to clear. Overall not a difficult job good luck!!
