Old 09-11-2010, 11:06 PM
BLUETHUNDER BLUETHUNDER is offline
BLUETHUNDER is on a distinguished road
Default every now and again i have a starting problem.
As the thread says. Not all the time but now and agin when i turn the key i get nothing. In the last few months i have fixed the starter. Replaced the ignition fuse. But i still have a problem. I am beginning to suspect the gearbox inhibitor switch. It seems that constant switching and turning with the ignition key and jiggling the auto lever throws the car to start. Are inhibitor switches a problem on the H2??.
Old 09-12-2010, 02:56 AM
Default Re: every now and again i have a starting problem.
Anyone??
Old 09-12-2010, 04:46 AM
mbdougl's Avatar
mbdougl mbdougl is offline
mbdougl is off the scale
bad ignition switch- that is the same thing mine did
Old 09-12-2010, 06:21 AM
Was it exactly the same as i described??
Old 09-12-2010, 06:47 PM
mbdougl's Avatar
Yep, it was working when I took it to the dealer but they could check the codes and an said it was part number 15242754
, of course with labor it was $285.
Old 09-16-2010, 06:25 AM
vetteSUT's Avatar
vetteSUT vetteSUT is offline
vetteSUT is on a distinguished road
Usually that means your starter is on the way out. What year is the truck? Mileage?
My vette did that for a couple times before the starter completely decided to stop. And that was like in 2008. Not bad, that starter got 13 years of life. I ended up spending 90 bucks to have it completely rebuilt.
Disconnect the battery and pull the starter yourself and take it to a shop that rebuilds starters. Save yourself a couple hundred bucks.
Also, if you can't start it at all, try tapping the starter with a hammer and give it another go.
Old 09-25-2010, 09:45 AM
H2R's Avatar
H2R H2R is offline
H2R is on a distinguished road
Did you replace the Ignition Switch.
2013 Sierra Denali
2012 Yukon Denali
1974 Corvette conv. (454ci)
31ft Gulf Craft Boat
