Old 09-12-2010, 09:51 AM
BLUETHUNDER BLUETHUNDER is offline
BLUETHUNDER is on a distinguished road
Default Another problem. Windshield washers
I went out in the Hummer this morning and had to clean the windshield. Noticed that the washers dont work. I have swapped fuses and relays,but still no joy. Any other ideas??.
Old 09-12-2010, 10:58 AM
Default Re: Another problem. Windshield washers
More baffled now,as the rear wash works and can hear the pump working. But nothing when i operate the front screen wash.Strange as all fuses and relays for both operate the same pump.Any ideas??
Old 09-12-2010, 02:39 PM
Just read all those threads. But there was nothing in there relating to the washers not working. I will pull the panel off tomorrow and open up the module and have a look at it.
Old 09-12-2010, 03:06 PM
twr's Avatar
twr twr is offline
hi check the front washer switch and make sure its sending the signal because the pump is working for the rear.
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
24 inch Starr 770 Hammer Rims
Gen 6 Lockpick
Gm bluetooth
Front + Rear Camera's
2005 Screamin Eagle, E Glide
http://twrbaggersplus.com/
Old 09-12-2010, 06:30 PM
Hi Tracy. Whereabouts is the front washer switch located?
Old 09-12-2010, 06:48 PM
twr's Avatar
twr twr is offline
Hi its the one that operates the washer, below is for a 2008 hummer i think your truck is the same.
When the windshield Wash switch is pressed, ground is applied through the switch contacts and the windshield washer switch signal circuit to the body control module (BCM) indicating the windshield wash request. The BCM then energizes the WPR relay, as stated above, and the front wash relay by applying ground through the control circuit to the coil side of the relay. With the wash relay energized, battery voltage from the WPR fuse is applied through the switch side of the relay and out to the control circuit of the windshield washer fluid pump. The washer pump is grounded through the de-energized rear wash relay. The wiper motor will operate for 2 wipe cycles after the wash switch is released.
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
Gen 6 Lockpick
Gm bluetooth
Old 09-16-2010, 08:40 PM
Easy Ed Easy Ed is offline
Find the problem ?
Ed
Old 09-17-2010, 03:11 PM
Nope!Looked for two hours at all probable causes. But we more than likely to suspect the problem is with the column stalk itself. There is no signal coming from the stalk to the pump.
For now we have switched the pump side of things from the rear to the front. So to operate the front washers i press the rear wash wipe.
Old 09-17-2010, 10:20 PM
Just read through the service manual about the washers and sure as crap that could be the problem :-(
Good Luck, Ed
